Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
02-15-2007, 11:50 | #1 (permalink) |
Junior Member Join Date: Jan 2007
Member: 441939 Status: Offline Thanks Meter: 1 | k750i joystick problem All the rest of the buttons work 100% on the keypad. Nothing works on the joystick at all. When the backlight turns off on the phone moving the joystick will not "wake" the backlight up again. There are no 'click sounds' comming from the speaker when the joystick is moved. I have inspected the board around the joystcik and there are no dry joints or sign of water damage. I have re-flashed the firmware 2 times with XS++ Any advice on what to do next would be great. |
02-15-2007, 14:34 | #6 (permalink) |
Banned Join Date: Jan 2007 Location: India Age: 34
Member: 432364 Status: Offline Thanks Meter: 270 | Change joystick if not ok see one more diagram for k750 jostick problem. So many time I solved k750 joystick problem by this solution. B.r. Sunil. |
The Following 4 Users Say Thank You to ..::Sunil::.. For This Useful Post: |
02-15-2007, 14:45 | #7 (permalink) | |
Member: 441939 Status: Offline Thanks Meter: 1 | Quote:
http://forum.gsmhosting.com/vbb/atta...0&d=1171546403 I tested between the pin at 12 o'clock and the pin at 9 o'clock at it field. I re-tested after touching it with fresh solder and it now works. Thanks. | |
02-16-2007, 22:07 | #8 (permalink) |
Junior Member Join Date: Mar 2006 Location: New Zealand Age: 43
Member: 251644 Status: Offline Thanks Meter: 0 | joystick of all the things in the world WD-40 must be the best. I have managed to get at least 4 different phones with bung joysticks to work with it. even when completely unresponsive. you just carefully move the joystick to one side add a little and do this all the way around (i have a sample wd-40 tube that works perfect but have heard of using a guitar pick of all things) then just keep moving it and then soak up what you can with a cotton bud and repeat about two more times. its like magic (c: |
k750i JOYSTICK problems...help me plzzzzzzzzzzzzzzzzzzzzzzzzzz | Dave.W | Sony Ericsson Hardware Repair | 25 | 12-10-2010 17:45 |
Problem, k750i joystick | freddy_c | Sony Ericsson | 5 | 08-01-2009 12:48 |
k750i joystick problem | jabed_net | Sony Ericsson Hardware Repair | 4 | 02-23-2009 18:41 |
K750i joystick problem | johnreza | Sony Ericsson Hardware Repair | 4 | 09-01-2006 15:49 |
k750i joystick problem | LYRE | Cruiser Suite | 12 | 05-13-2006 13:43 |
