Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
01-11-2009, 10:28 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: india Age: 38
Member: 650853 Status: Offline Thanks Meter: 118 | k750i rsstart problem CARD SERIAL: 00074295 Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 loader header not accepted Can't load ID loader ! Elapsed: 11 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:200D Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35570601800892 CERT:RED FLASH CID:49 COLOR:RED Model:K750i Brand:Generic MAPP CXC article: R1CA021 prgCXC125954_CHINA_CL MAPP CXC version: R1CA021 Language Package:APAC_1 CDA article: CDA102337/1 CDA version: R2A Default article: cxc125953 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 32 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35570601800892 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok FOUND VERSION "R1CA021_CXC125954_CHINA_CL" writing "C:\Program Files\setool\files\k750\cid49\K750_R1CA021_MAIN_CH INA_CL_RED49.mbn" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:313 Will flash 313 blocks... SSW loading returns:0 writing "C:\Program Files\setool\files\k750\cid49\k750_R1CA021_APAC1_F S.cry" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:153 Will flash 153 blocks... SSW loading returns:0 LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V23 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing "tpa/preset/custom/C3_PCA_G3v2.cer" writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" writing "tpa/preset/custom/customize.xml" writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" writing "tpa/preset/custom/Entrust.net Root Certificate.cer" writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" writing "tpa/preset/custom/GAMES_HOOK_3.itm" writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" writing "tpa/preset/custom/Root.cer" writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" writing "tpa/preset/custom/ThawtePremium.der" writing "tpa/preset/custom/ThawteServerCA.cer" writing "tpa/preset/custom/Utiroot.cer" writing "tpa/preset/custom/VeriSignClass3Root.cer" writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" Processing script "C:\Program Files\setool\rest\R1CA021_CXC125954_CHINA_CL"... Phone detached Elapsed: 579 secs. my k750 i has rebooting problems. i've tried flashing it and the first time i on it after flashing it will not have and problem... the moment i off and re on the phone, i will encounter restarting problems.. the phone will restart about every one minute or each time i try to access any functions.. i suspect it might be hardware problem.. which part of the hardware do you all think could be the problem? help me |
The Following User Says Thank You to micro_hsr For This Useful Post: |
k750i rsstart problem | micro_hsr | SETool2 | 0 | 01-11-2009 10:34 |
Flasing K750i + k700i problems... help needed. | KSM1 | HWK | 44 | 04-20-2006 09:06 |
K750i unlock problem | fear4 | TOTAL MultiServer | 0 | 08-18-2005 22:28 |
K750i Camera Problem | danielkhaw | Cruiser Suite | 4 | 08-11-2005 18:50 |
K750i CustomeFS problem | pgtl | Cruiser Suite | 4 | 08-10-2005 15:43 |
