Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
06-01-2009, 09:15 | #1 (permalink) |
No Life Poster Join Date: Mar 2006
Member: 246691 Status: Offline Thanks Meter: 54 | k790i dead......help....... v0.915035/UNI CARD SERIAL: 00058104 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:101000000000000 Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35220601059020 CERT:N/A FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35220601088401 Model (from GDFS):K790i Brand:Sony Ericsson MAPP CXC article: R1CC003 prgCXC1250477_GENERIC_EV MAPP CXC version: R1CC003 Language Package: S_ASIA_LEVAN CDA article: CDA102568/110 CDA version: R4A Default article: cxc1250491 Default version: R1CC003 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1CC003_CXC1250477_GENERIC_EV" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 8 secs. what the problem?i finish all solution that my buddy give me but nw the fon cannot switch on already help......................................:confuse d: |
06-01-2009, 09:17 | #2 (permalink) |
Member: 246691 Status: Offline Thanks Meter: 54 | SIGNED MODE (USING SERVER) Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35220601059020 CERT:N/A FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "C:\Documents and Settings\winxp_Service\Desktop\New Folder (7)\R1ED001_CHINA_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:4420 Will flash 221 blocks... SSW loading returns:0 writing "C:\Documents and Settings\winxp_Service\Desktop\New Folder (7)\R1ED001_APAC_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:4740 Will flash 237 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing "tpa/preset/custom/C3_PCA_G3v2.cer" writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" writing "tpa/preset/custom/customize.xml" writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" writing "tpa/preset/custom/Entrust.net Root Certificate.cer" writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" writing "tpa/preset/custom/GAMES_HOOK_3.itm" writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" writing "tpa/preset/custom/Root.cer" writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" writing "tpa/preset/custom/ThawtePremium.der" writing "tpa/preset/custom/ThawteServerCA.cer" writing "tpa/preset/custom/Utiroot.cer" writing "tpa/preset/custom/VeriSignClass3Root.cer" writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" Processing script "C:\Documents and Settings\winxp_Service\Desktop\readsecunits.txt".. . Reading GDFS var 0002/0E5A Reading GDFS var 0002/0E48 Reading GDFS var 0001/0851 Reading GDFS var 0000/0006 Reading GDFS var 0000/000E Reading GDFS var 0000/0013 Reading GDFS var 0000/001C Reading GDFS var 0000/0018 Reading GDFS var 0000/00AA Phone detached Elapsed: 543 secs. |
k790i charging help! | khan6653 | Sony Ericsson Hardware Repair | 1 | 11-06-2009 06:51 |
Need K790I EROM ,help! | davilixian | Cruiser Suite | 4 | 10-14-2007 06:42 |
K790i unlock help | ..::Sunil::.. | Cruiser Suite | 2 | 02-03-2007 13:29 |
