Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 10-05-2006, 00:16   #1 (permalink)
rjsoo7's Avatar
Member: 39014
K800 Display & Backlight ways
Hi freinds,
I have K800 that had no White(Back) Light .. It was because of Water spilled on it.
Now I managed to turn on the phone , everything is OK except :
1- Back light
2- Flash light
Anyone knows the part responsible ? and where it is located
Thanks
Old 04-18-2007, 12:18   #2 (permalink)
mehdi_naghous's Avatar
Member: 158513
i have this problam also
please help me
Old 07-28-2007, 05:34   #3 (permalink)
Member: 118190
Pls Check R2554/c2559/v3113
Old 07-28-2007, 21:58   #4 (permalink)
malcomxyz's Avatar
Member: 68105
Alos check pads at keypad connector...on right side (XXX)
000000XXX
000000000
Old 12-16-2007, 04:26   #5 (permalink)
Member: 124496
Old 12-16-2007, 19:16   #6 (permalink)
boengo's Avatar
Member: 401010
i just have this...hope can help all..
best regards
Hanscooly-Boengo
The Following 14 Users Say Thank You to boengo For This Useful Post:
Old 05-28-2008, 17:41   #7 (permalink)
Member: 767784
SALAAM to all.i have also this problem plz help me.
Old 06-19-2008, 21:15   #8 (permalink)
Registered User
Member: 259742
hi my mobile K800i problum is display backlight not display incoming call any bady know
Old 06-26-2008, 20:14   #9 (permalink)
Member: 789344
Thumbs up k800 no lights
best regards
Hanscooly-Boengo
it is really works.... funtastic. jst one jumper cable & it solved.
regards from me Willy..... Indonesia.
and thanks
Old 07-24-2008, 14:06   #10 (permalink)
Member: 1400
Hallo,
Can you please make clear what jumper exactly you place?From pin 1 of the LCD connector to where?
Thanks a lot.
Old 07-25-2008, 19:32   #11 (permalink)
Member: 821266
It works !!! I solder the no.1 lead anode to TP3100 spot and my k800i baclight is back !
What is groud, isn't it rather Ground ? (sorry for my bad english)
Where can i solder the ground An example of a ground spot on a k800i pcb plz !
Is it really important to solder the ground ??? Because i just solder the n.1 lead to TP3100, without soldering the ground, and the backlight works !
Old 07-25-2008, 19:43   #12 (permalink)
Member: 821266
What is groud ?
And where can i solder it ? an example of a ground spot on a k800i pcb plz
The Following 16 Users Say Thank You to chaozu For This Useful Post:
Old 07-25-2008, 19:51   #13 (permalink)
Member: 821266
k800i_schematics :
h*t*t*p://w*w*w.megaupload.com/?d=YMDN439L
without ***
Old 07-26-2008, 11:45   #14 (permalink)
Member: 1400
Guys thank you very very much!That was very useful information.
But my problem still exists,I have no lights at all...It must be something else...
But thank you anyway!
Old 07-28-2008, 09:43   #15 (permalink)
Member: 789344
Wink
Originally Posted by spawoolm View Post
Hallo,
Thanks a lot.
just make the jumper as picture that load from boengo, without the connecting the "groud". just from pin 1 to the point near the connector
The Following User Says Thank You to wtjhia For This Useful Post:
7270when the backlight of display & keypad will light up by itself beneto Nokia Hardware & Hardware-Repair Area 1 05-21-2008 15:14
backlight ways on v3x b2l80 P2k Series 0 11-10-2006 05:06
2600 Nokia Backlight Ways mattakins Nokia Hardware & Hardware-Repair Area 3 09-14-2006 10:14
T720i after change display no backlight ext.LCD bodzo2002 P2k Series 0 01-25-2006 12:41
Alcatel BF3 0165 display dead, backlight works. rodney123 Alcatel TCL Hardware Repair Section 0 12-01-2005 19:05
Page generated in 0.44603 seconds with 12 queries
