Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 11-05-2008, 07:05   #1 (permalink)
Member: 384098
Thanks Meter: 33
k800 flash ic ,help answer
hello , do u guys know k800 flash ic is it compatible to use on all DB2020 phone ? because the salesman told me k800 flash ic only work on k800 and k810. k550 flash ic is compatible with z610 ,w610,w660....
The Following User Says Thank You to leong0723 For This Useful Post:
Old 11-05-2008, 07:34   #2 (permalink)
Super Moderator
acyl2000's Avatar
Member: 1922
Sonork: 100.64645
Thanks Meter: 692
post out the flash chip code..
br
acyl2000
The Following User Says Thank You to acyl2000 For This Useful Post:
Old 11-05-2008, 07:58   #3 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
I normally use DB2020 flash chips for all of them and works pertfect.
The Following 2 Users Say Thank You to meisam For This Useful Post:
Old 11-05-2008, 17:03   #4 (permalink)
Member: 387482
Thanks Meter: 15
as i know...
all of them also work...
The Following User Says Thank You to Q_QOooo For This Useful Post:
Old 11-18-2008, 09:10   #5 (permalink)
Member: 258092
Thanks Meter: 11
can anyone kinda post the flash ic of k800 to me? i am kinda new to this phone repair...
and what of symptom the phone will get if the flash ic faulty ?
white screen hang?
Old 11-13-2009, 13:08   #6 (permalink)
Member: 384098
Thanks Meter: 33
thanks all ~ the salesman try to cheat me zzz
turks,db2020 flash chip faulthy can cause u failed to flash the gdfs part of the phone.
Old 11-14-2009, 06:40   #7 (permalink)
Member: 711270
Thanks Meter: 30
Same 1 ...ntg different...ic legs same then can lar ..
The Following User Says Thank You to thequestions For This Useful Post:
k800 after change flash ic how to flash ...? jimmyyew1981 DreamBox 7 03-16-2009 18:19
k700 heat up near flash ic help me plz shani72 Sony Ericsson Hardware Repair 1 08-05-2008 06:37
K800 Flash ic Changed with K790..But.. LoveLess SETool2 0 07-26-2008 16:40
K800 506moyobe Flash ic Tp where jekjae DreamBox 5 04-30-2008 10:13
SonyEricsson K800 flash IC needed in Morrocco summer_20xx Wanted Products 2 01-30-2008 12:39
Page generated in 0.16401 seconds with 9 queries
