Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
05-21-2008, 10:19 | #1 (permalink) |
Insane Poster Join Date: Apr 2007
Member: 487904 Status: Offline Thanks Meter: 12 | ..:: k800 lcd light solution :.. k800 with no lcd light problem any help ??? i think that must be a jumper solution like " k750 lcd light problem " pls share ur knowledge thx in adv |
The Following User Says Thank You to newstudent For This Useful Post: |
05-21-2008, 14:25 | #3 (permalink) |
Member: 487904 Status: Offline Thanks Meter: 12 | thx dear friend but there is two solution i think 1) change L3103 2)make jumper from left side of C3104 to right upper side of lcd connector which of them is for lcd solution ?????? |
The Following 2 Users Say Thank You to newstudent For This Useful Post: |
07-03-2009, 07:39 | #12 (permalink) |
Junior Member Join Date: Jul 2008 Location: NEPAL(suryabinayak)
Member: 817331 Status: Offline Sonork: snny Thanks Meter: 13 | make lcd led connection serries to parallel then remove light ic(6 pin) 1 is ground, 1 is input another 4 pin (same connection) are output and connect (-)volt to ground ,(+)volt to input pin . if input puls ok it work 1000%. it is last solution tri it & injoy. 9same |
The Following User Says Thank You to sunnyraj100 For This Useful Post: |
N95 8gb no lcd and lcd light solution | jhoesteve | Nokia Hardware & Hardware Repair | 25 | 01-21-2011 17:37 |
W810i No LCD Light Solution (Quick Fix) | Speed_Demon | Sony Ericsson Hardware Repair | 24 | 12-09-2010 13:05 |
need 6260 lcd light solution | erkan06us | Nokia Hardware & Hardware Repair | 10 | 07-09-2009 18:11 |
V3 No Lcd Light Solution ! | greeni222000 | Motorola Hardware Repair | 5 | 01-20-2008 13:01 |
3250 lcd light solution | kanwal | Nokia Base Band 5 ( BB-5 ) | 0 | 05-17-2007 09:20 |
