Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
03-02-2007, 13:46 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: POLAND Age: 42
Member: 340047 Status: Offline Thanks Meter: 20 | K800i "Charging error, stop charging" Can anybody help me? |
03-05-2007, 09:53 | #4 (permalink) |
Member: 340047 Status: Offline Thanks Meter: 20 | I chek on 2 original battery and 2 original charger. And nothing. The primary problem is discharging battery. "Charging error" problem is on unoriginal battery. Phone discharging battery also when he is switched off. Sory for my english |
08-31-2007, 17:08 | #6 (permalink) |
Crazy Poster Join Date: May 2004 Location: in town Age: 44
Member: 66062 Status: Offline Thanks Meter: 2 | K800i charger problem solved by CodeMaker guys my advice for k800i to sort the charging bllok you should heat with a heater for about 5 minut to recover the moisturise and hope it will work change charging block and check the battery is it not fully charge check the main charger so that should be ok 2 and try maybe need to flash the gdfs som file missing |
05-29-2011, 05:58 | #12 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | check phone short or not with power supply ans post result...i can help u.. re u from srilanka can post in sinhala .. |
The Following User Says Thank You to .::Gsm_Srilanka::. For This Useful Post: |
05-29-2011, 06:55 | #13 (permalink) | |
Registered User Join Date: Dec 2009 Location: HABARADUWA - Sri Lanka Age: 39
Member: 1179630 Status: Offline Sonork: 100.1644820 Thanks Meter: 80 | Quote:
charging error, stop charging කියල වැටෙනව සමහර වෙලාවට Battery nam bahinne ne.... mama charger,battery maru karaka baluwa ... hari giye ne.... lede awilla thiyenne aithi karaya car charger ekaka gahala.... mama power ic eka heat karala baluwa. eta passe thama nam awe ne.... Last edited by wasangaama; 05-29-2011 at 07:00. | |
05-29-2011, 07:04 | #14 (permalink) |
Member: 1133072 Status: Offline Thanks Meter: 505 | i think ur power ic faulty..heat karata hariyai kiyala mama hitane ne..balanna try krala parashnayak awaoth mata p.m ekk danna mama help kaannam .. |
Serious error. Stop charging. Stop using your phone. Call sonyericsson call center | sammiebaby_03 | Sony Ericsson | 17 | 04-26-2013 11:36 |
K610i Serious Error,stop charging,stop | tornado2008 | Sony Ericsson Hardware Repair | 9 | 02-13-2011 13:32 |
k310 /k320 / w200 " STop charging" | mukeshdurg | Sony Ericsson Hardware Repair | 7 | 12-19-2010 03:07 |
SOLUTION !!k550i serious error, stop charging,stop using ur phone contact callcenter | harryscelclinic | Sony Ericsson Hardware Repair | 19 | 06-15-2010 13:18 |
W810i shows "Charging error, Stop Charging" and "Charging Alien battery" after flash | Jazz | Cruiser Suite | 16 | 03-23-2008 16:49 |
