Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-10-2008, 13:31 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 251314 Status: Offline Thanks Meter: 2 | K800i DAMAGED FIRMWARE,GDFS OR EMPTY PHONE I have SE k800 and after startup its blinking. On SETool its look like this: v0.914034/UNI CARD SERIAL: 0001**** Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 erom_readvar: error reading unit 1/851 error while reading SIMLOCK SIGNATURE unit phone was tampered with other software SECURITY UNITS CAN'T BE READ ! DAMAGED FIRMWARE,GDFS OR EMPTY PHONE Can't load ID loader ! Elapsed: 9 secs. Is there any solution for phone like this? I dont have any backups. |
07-10-2008, 14:03 | #3 (permalink) |
Member: 251314 Status: Offline Thanks Meter: 2 | When try to flash it or make recovery i get almost same info: ChipID:9900,EMP protocol:0301 erom_readvar: error reading unit 1/851 error while reading SIMLOCK SIGNATURE unit phone was tampered with other software SECURITY UNITS CAN'T BE READ ! DAMAGED FIRMWARE,GDFS OR EMPTY PHONE phone pre-boot failed,possible RECOVERY needed. Elapsed: 11 secs. |
07-10-2008, 14:13 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | use server and write this script in text use ufs interface gdfswrite:0001085144554D4D5944415441 BR MAPLE GSM(UMER) |
The Following 2 Users Say Thank You to maplegsm For This Useful Post: |
07-10-2008, 15:24 | #5 (permalink) | |
Member: 251314 Status: Offline Thanks Meter: 2 | Quote:
Anyway, somehow i can almost flash it: ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35975701059495 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CID52 BYPASS PROCEDURE STARTED Processing part1... Processing part2... Processing part3.... OTP LOCKED:1 CID:51 PAF:1 IMEI:35975701059495 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" HOLD "C" BUTTON AND ATTACH PHONE CID52 BYPASS PROCEDURE FINISHED ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed:458 secs. | |
07-10-2008, 15:38 | #6 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: PT Age: 40
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | use SETOOL check for a flash with same CID MAIN+FS in setings check 1st opinion ( SERVER TO FLASH ) chose complect phone after flash. Flash the phone and all be ok alredy tested. OBS: dont forget use USB CABLE Quote:
The Following User Says Thank You to guedes666 For This Useful Post: |
07-11-2008, 18:45 | #8 (permalink) |
Member: 251314 Status: Offline Thanks Meter: 2 | Hello again. I have new problem with same phone.. its hang in random moments like when im calling, watching some movies or its just come back to blinking. I tried to flash with other version but problem not solved Any sugestions? |
07-11-2008, 20:27 | #9 (permalink) | |
Moderator Join Date: Sep 2002 Location: Serbia/Hungary Age: 42
Member: 15994 Status: Offline Thanks Meter: 263 | Quote:
this solution is 100% tested & proven | |
W200 damaged firmware/gdfs | Eed07 | Sony Ericsson | 1 | 02-08-2009 12:05 |
K800i Dead-its Gdfs Region Damaged-help | zonetrichur | SETool2 | 8 | 09-04-2008 13:58 |
k810 damage gdfs and dead phone | ronkiton | DreamBox | 1 | 03-28-2008 12:45 |
k800i w850i white screen or gdf problem | destinyhammed | Cruiser Suite | 3 | 03-04-2008 05:08 |
D900i Dead--is it Firmware, Flash or damaged Hardware? | Yanktar03 | UST Pro II | 20 | 11-02-2007 16:27 |
