Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 06-09-2007, 05:17   #1 (permalink)
Member: 453687
Thanks Meter: 2
K800I - NO USB connection
I have been given a W800i however it does not matter what we try, it is unable to be seen via the usb port. Other W800i's and K750I tried and are all OK
This unit must have a USB problem..
I can not upgrade as when I go via the process the unit comes up into Phone or Music mode and not upgrade as it does not see the USB connection.
How can I Trouble Shoot this further ?
Can I some how flash or run a diag tool from the mem card ?
NOTE: When being used as a phone this unit works but DRAINS battries quickly as well ? A seperate or related problem ?
Please help.
Mark
Old 06-09-2007, 06:02   #2 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
check clean pcb with ipa or same. and dry it well with hotair.
check usb connection also
wbr
Old 06-09-2007, 08:31   #3 (permalink)
Member: 388978
Thanks Meter: 88
check system connector, IC USB (below RAM (IC Nand)).
Old 06-09-2007, 09:26   #4 (permalink)
Member: 453687
Thanks Meter: 2
wbr
Done that, cleaned and scrubbed all connectors. Had the thing appart more than I can to think.
Have always checked that the 3 push in connectors are firm as well as the edge connector that allows the USB / Interface cable to be connected.
Pulled it all down again, connected and Battery is charging... BUT still not recognised as being connected :-( Ready to use as a BRICK.
Sorry it is a W800i not a K800i (PS. Is there any major diferences?)
Old 06-09-2007, 21:11   #5 (permalink)
Aishur's Avatar
Member: 28188
Thanks Meter: 579
Yes, different plateforms db2010 and db2020
With w800i, for servicing, you will need a serial service cable (FTDI, rs232, ufs..)
Best regards,
Aishur
Old 06-09-2007, 21:25   #6 (permalink)
Aishur's Avatar
Member: 28188
Thanks Meter: 579
Hi
Sorry for a second post
You need also to check or to weld the cable and/or phone connectors
Best regards,
Aishur
SE K750 W800 W810 no USB connection solved here mahcin Sony Ericsson Hardware Repair 1 03-09-2010 17:49
k800i locked in usb connection mode reighdgm5562 Sony Ericsson Hardware Repair 2 11-12-2009 07:17
K750i no USB connection chunkt Sony Ericsson Hardware Repair 0 03-23-2008 21:46
2x w880i red light flashing and no usb connection JEEV2002 Sony Ericsson 7 03-02-2008 11:39
HELP!: Flashed N6280 -> N6288 = No USB connection Arbiter Nokia Base Band 5 ( BB-5 ) 2 11-20-2006 11:27
Page generated in 0.17632 seconds with 10 queries
