Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
10-01-2008, 13:09 | #5 (permalink) |
Freak Poster Join Date: Dec 2002
Member: 18369 Status: Offline Thanks Meter: 3 | Hi I also have a K800i that indicates in the display that it is charging but the battery get no charge at all. The battery shows that it has some % charge but it only gets lower even when charger is connected. I have checked that both the battery and charger works 100% ok in another phone. Has anyone fixed this problem before ? |
10-03-2008, 22:16 | #6 (permalink) |
Junior Member Join Date: Oct 2008
Member: 875405 Status: Offline Thanks Meter: 0 | hi there! k800 was left to charge overnight. in the the phone was hot and turned off.whenever i tried to switch it on there was no response!any solution.If is the power ic could you advise where to get it from? thanx |
10-03-2008, 23:56 | #7 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 696888 Status: Offline Thanks Meter: 5 | first connect the charger to phone and wait for several second nad after it... measure voltage from the battery pin connector by voltmeter.... it,s must about 3.7 or more.......... if it,s lesser you must replace power ic........... good luck |
Siemens S55 shows charging but not charge | SVH | Siemens Hardware Repair Area | 6 | 03-03-2005 11:46 |
A800 show charging but not charge | NELIX | VLSI, Conexant, Skyworks and Old Models | 12 | 08-22-2004 18:00 |
Alcatel BE3 show charging but not charges | SVH | Alcatel TCL Hardware Repair | 1 | 08-02-2003 23:26 |
3310 show charging but not charge!!! | florinmar | Nokia Hardware & Hardware Repair | 3 | 05-28-2003 09:25 |
3210 shows charging, but not charge actually. | sat | Nokia Hardware & Hardware Repair | 6 | 11-02-2001 01:28 |
