Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
01-10-2010, 14:12 | #1 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 857488 Status: Offline Thanks Meter: 41 | K810i flashing problem v0.915057/UNI CARD SERIAL: 000000ok Loaded 51 flash descriptors CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEIk CERT:N/A FLASH CID:52 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 81 secs. now when i want to flash my phone its shows this error v0.915057/UNI CARD SERIAL:0k Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110100000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEIk CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 9 secs. plz help me about this problem if its gdfs problem plz post gdfs file for K810i |
01-10-2010, 14:15 | #2 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: SWEDEN-China-Thailand-Singapor
Member: 917893 Status: Offline Sonork: 100.1584763 Thanks Meter: 3,156 | Quote:
gdfs file is in your setool/gdfs folder and post in setool section not hardwarerepair section | |
The Following User Says Thank You to GSMman187 For This Useful Post: |
01-10-2010, 19:45 | #6 (permalink) |
Product Supporter Join Date: Dec 2001 Location: in my skin Age: 47
Member: 8086 Status: Offline Thanks Meter: 180 | Phones with symptom: not booting via 'C' and cable plugin only via so called "bootrom" mode by 2+5 and cable plugin are with damaged EROM (usb boot) area. You have to repair EROM , no need TP only a few credits on ur setool account and make RESET phone option, what makes phone certificate to BROWN and in BROWN state U can upload correct EROM (and gdsf too if needed). |
The Following User Says Thank You to gyuszko For This Useful Post: |
k810i bluetooth problem | barnes1519 | Sony Ericsson Hardware Repair | 8 | 01-09-2011 08:22 |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
K810i flashing problem | khan0001 | Sony Ericsson | 2 | 01-10-2010 18:37 |
k810i gdfs repair ok but flashing problem. | software zone | DreamBox | 9 | 04-10-2008 05:52 |
K810i GDFS problem showing K700 | leomaxuk | Sony Ericsson | 3 | 10-02-2007 15:54 |
