Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
12-19-2006, 10:34 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: uk
Member: 240930 Status: Offline Thanks Meter: 16 | K750 battery charge low fastly!! warmed . now battry charge lowed very fastly .I try flash it by setool3 but not boot phone i use test point but not boot again. i changed v2681 and v2802 and remove n2802 but the phone not boot for flash and charge battry lowed fastly,i changed battery but it have some problem !!! what is problem? |
12-20-2006, 04:20 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 41
Member: 356202 Status: Offline Thanks Meter: 46 | it might be battery problem.. but the most possible is the set is shorted or has a leak.. check battery connector + and - with multi tester.. if the set is short.. isolate PA by removing the coil beside pa.. br |
05-01-2007, 09:20 | #6 (permalink) | |
Member: 240930 Status: Offline Thanks Meter: 16 | Quote:
if the set is short.. isolate PA by removing the coil beside pa.. ?? | |
k750 battery low | germany | Sony Ericsson Hardware Repair | 8 | 06-25-2012 06:54 |
cect p168c not charge,low voltage 2,5v on battery pin solution? | nykocam | Chinese Models & Cloned Phones | 3 | 03-09-2010 07:56 |
nokia 6600 low battery charge problem | mathai69 | Nokia Hardware & Hardware Repair | 0 | 10-06-2009 07:37 |
p990i charging but battery still low bat. | johed | Sony Ericsson Hardware Repair | 0 | 05-05-2009 05:49 |
1100 fast charge & fast decharge | kevin2001 | Nokia Hardware & Hardware Repair | 3 | 02-08-2008 10:13 |
