Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 02-16-2008, 15:02   #1 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
K850 Keypad and Back Blue Light Only..
I got K850 with Keypad and Back Blue Light Only....Full flashed with Setool but still same..Any HW solution?
Old 03-06-2008, 11:18   #2 (permalink)
Member: 152665
Sonork: 100.1591630
Thanks Meter: 4
I got this same problem also.Any one got slolution for settle this.On the phone only keypad and back Blue got light.LCD is blank.Phone are hang at that.
Old 04-04-2008, 13:26   #3 (permalink)
begginer's Avatar
Member: 170469
Thanks Meter: 6
i have same problem too,i have 3 k850 with this problem,
Old 04-07-2008, 00:29   #4 (permalink)
Member: 736968
please help. have a k850 that needs water damage treatment. however we can not work out how to dissasemble the phone. can someone please help with pictures or description on how to dissasemlbe this phone
Old 04-07-2008, 20:01   #5 (permalink)
Crazy Poster
Member: 685120
Thanks Meter: 41
same problem with my k850 any one have solution for that
The Following User Says Thank You to mfaraz For This Useful Post:
Old 04-18-2008, 08:24   #6 (permalink)
Member: 751371
in this case it's known as a BROD = Blue Ring Of Death..
if i'm not mistaken it will happened after you changed your firmware to R1EA031...
maybe after this you can change your firmware to the latest one which is R1EA037
Old 10-26-2008, 17:22   #7 (permalink)
RAMSUL's Avatar
Member: 112275
Thanks Meter: 34
I same problem, pls give solution
Old 11-10-2008, 06:44   #8 (permalink)
Member: 562509
Thanks Meter: 7
i have also problem on my phone k850...after pressing key like down it will appear blackscreen only...
whos any body have a diagram for this?
thank you so much.
Old 11-11-2008, 18:37   #9 (permalink)
antoniolcrd's Avatar
Member: 283943
Thanks Meter: 124
Done
well,
got one today and just repaired like that:
15:13:17 SE A2 Flasher v1.04 by Cruiser Team
15:13:17 Initializing...
! 15:13:17 1. Choose the phone model
! 15:13:17 2. Select main firmware flash file (*.a2sw)
! 15:13:17 3. Select raw FS flash file (*.a2fs)
! 15:13:17 4. Please connect the phone while holding its C button…
15:13:48 Connecting via SEMC USB Flash Device (USB1)…
15:13:48 Device driver version: 2.1.0.0
15:13:48 Device driver date: 3-20-2008
15:13:48 Connecting to the baseband CPU...
15:13:48 Entering baseband CPU service mode...
15:13:48 Detected chipset: DB3150
15:13:48 Boot mode: EROM
15:13:48 EROM version: 1200-4341 SEMCBOOT R6A008
15:13:48 Sending loader...
15:13:49 IMEI: 354414xxxxxxxx
15:13:49 OTP CID: 52
15:13:49 OTP area status: Locked
15:13:49 Product type: Retail
15:13:49 Effective color: Red
15:13:49 Sending loader...
15:13:54 Importing flash files…
15:13:58 About to flash 76 MB of data…
15:13:58 Programming flash…
15:13:58 D:\cdc\sonyericsson\k850\K850i_12004400_Generic_R1 EA037_Red52.a2sw
15:21:57 Final verification…
15:22:07 Programming flash…
15:22:07 D:\cdc\sonyericsson\k850\K850a_1200-5441_America_R1EA037_Red52.a2fs
15:27:11 Final verification…
15:27:19 Starting file system…
15:27:41 Writing files…
15:27:41 Turning off the phone...
15:27:41 Done.
! 15:27:41 Please disconnect battery and cable from the phone!
But, consider i´ve tried 2 pieces before with no success. This one worked great.
B. r
The Following User Says Thank You to antoniolcrd For This Useful Post:
Old 11-18-2008, 17:32   #10 (permalink)
Member: 752352
Thanks Meter: 3
i ve got same problem whenever i power on the phone it will boot but hang and then i release battery and insert it back and then power on the phone it will do the same thing as others got
we all need solution urgent.....thanx
Old 11-18-2008, 17:34   #11 (permalink)
Member: 752352
Thanks Meter: 3
i ve tried through setools but i think its hardware problem
The Following User Says Thank You to salmank22 For This Useful Post:
Old 11-19-2008, 06:36   #12 (permalink)
Member: 446221
Thanks Meter: 23
Bro, flash it with correct files with universal box, it will work 100% i did more times same problem
Old 11-22-2008, 08:33   #13 (permalink)
Member: 752352
Thanks Meter: 3
Thank you when i will manage to get universal box i will try your solution and will post Take care
Old 11-22-2008, 11:15   #14 (permalink)
Member: 863656
if anyone want to sell i will buy
Old 01-24-2009, 10:12   #15 (permalink)
Member: 129947
Thanks Meter: 16
i have k850 when u put battry a red light just come on need help on how to fix it. Thanks in advance.
6300 only side blue light only !!!!!! msantar Nokia Hardware & Hardware Repair 28 07-10-2012 05:19
6300 Very Strange Blue Light Only Already Flash And Check Hardware MUTUAL Nokia Hardware & Hardware Repair 14 05-19-2010 07:21
nokia 6300 blue light only any idea ? aleem26 Nokia Hardware & Hardware Repair 0 02-01-2009 18:13
>>> V3xx - KPAD BLUE LIGHT ONLY - SOLUTION <<< RNC_EBM Smart-Clip 1 02-19-2008 11:27
6300 Blue lights only freewaycomms MT-BOX 14 08-29-2007 16:54
Page generated in 0.22311 seconds with 11 queries
