Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
04-29-2008, 23:21 | #1 (permalink) |
Crazy Poster Join Date: Aug 2004 Age: 44
Member: 77613 Status: Offline Thanks Meter: 1 | k850 keypad still does not work after replacment my girlfriends phone statrted to play up ie when pressing cursor button it would do something entirely different to what was pressed so i opened it up following some guides and noticed her keypad membrane flex had split or i was to zeluis to open it and it tore ifso what caused the problem in the first place???? so we got a new keypad membrane from ebay installed it took care also but now the touchpad does not work any ideas please as we cant start the phone without this feature also there was a silver peice that came aprt from the phone does anyone know its location it is a bout 1 inch long flat at one side with a diagonal cut at the other side with 2 raised peices in centre one bigger than the other in lenght as illustrated in picture |
The Following User Says Thank You to wreksta For This Useful Post: |
04-30-2008, 12:59 | #2 (permalink) |
Major Poster Join Date: Feb 2005 Age: 59
Member: 112858 Status: Offline Thanks Meter: 6 | I have the same problem as in my touch buttons don,t work, ive installed a new keypad membrane from ebay and still my touch buttons don,t work. I take it they are nothing to do with the screen. or could it be a software fault. ive reflashed the phone but still no joy. if anyone has a solution it would be much appriciated...... |
The Following User Says Thank You to mdoignie For This Useful Post: |
05-01-2008, 13:07 | #4 (permalink) |
Member: 112858 Status: Offline Thanks Meter: 6 | that silver part is the camera buttons backlight cover which goes inside the front housing where the buttons are on the left side (as you look at it inside the front cover). if you look on the other side you will see a similar plastic strip like the one you have shown. Mike |
05-02-2008, 12:35 | #5 (permalink) |
Member: 112858 Status: Offline Thanks Meter: 6 | reflashed my 850i had same problem with keypad touch, then decided to clean the gold touch pads of my new keypad with one of those fibre pens and all working now, so it may help if you give the touch pad a clean to solve the problem of the touch pad not working. you have nothing to loose. |
e65 keypad ic does not work properly | amardeepsahi | Nokia Hardware & Hardware Repair | 16 | 09-21-2011 14:41 |
Touchscreen not working after replacing display | Kais_Unlocker | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 04-24-2009 17:50 |
5500 Sport still not working after replacing LCD | woonuts | Nokia Hardware & Hardware Repair | 2 | 07-27-2008 23:34 |
N73 LCD and Keypad Lights does not work.. need help please | bakhshalvi007 | Nokia Hardware & Hardware Repair | 3 | 03-13-2008 11:45 |
5510 keys not working after replacing LCD | roughana | Nokia Hardware & Hardware Repair | 1 | 04-06-2004 07:27 |
