Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 07-05-2008, 18:18   #1 (permalink)
Member: 201816
Thanks Meter: 6
K550 killed while unlock pls help... :-(
Hi to all!
I try with the new setool v0.914037 to unlock one k550 CID52 but i forgot to download the rest file for it.I finisht the unlock procedure and I got a
message :
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
Trying to launch embedded bootloader...
INT LDRB2020_PRELOADER_FOR_SETOOL2
Flash ID check:897E
Flash props sent ok
FOUND: R6BC002_CXC1250669_GENERIC_LI
Restore from:R6BC002_CXC1250669_GENERIC_LI
can't open file "G:\Mobile\se\Setool 2\rest\R6BC002_CXC1250669_GENERIC_LI"
full sig complete.
USERCODE RESET TO "0000"
Searching...
Firmware SIMLOCK check determined.
Unlock DONE
Elapsed: 718 secs.
Now is my phone death.
If I try to flash or write back the original GDFS I got tihis message:
Loader refused to start GDFS services,error is:29
loader GDFS startup failed, that is fatal
What can I do now? pls help me...
Thnx to all!
Old 07-05-2008, 18:34   #2 (permalink)
Member: 801229
Thanks Meter: 7
easy prob
boy reflash ur phone fully i mean (mcu fs cust) dont forget to go setting tab use server complete unlock and bybass sec and ur prob is gone with the windcoz u have prob with rest files ..............................
Originally Posted by Joda View Post
Hi to all!
message :
Speed:921600
Flash ID check:897E
Flash props sent ok
full sig complete.
Searching...
Unlock DONE
Elapsed: 718 secs.
Thnx to all!
Old 07-05-2008, 18:58   #3 (permalink)
Member: 201816
Thanks Meter: 6
I try to reflash but I got all the time this message:
v0.914037/UNI
CARD SERIAL: 00010850
Loaded 51 flash descriptors
POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK
DONE EXTRACTING.
SIGNED MODE (USING SERVER).
ALTERNATIVE SECURITY BYPASS ENABLED.
Speed:921600
OTP LOCKED:1 CID:51 PAF:1 IMEI:35665701468358 CERT:RED
FLASH CID:52 COLOR:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
Elapsed: 11 secs.
Old 07-05-2008, 19:02   #4 (permalink)
Member: 82132
Thanks Meter: 15
Go to settingss and mark only use signed mode and flash phone with main and fs
Old 07-05-2008, 19:09   #5 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
Elapsed: 11 secs.
it seems gdfs zone damage..
try to repair gdfs
Old 07-05-2008, 19:12   #6 (permalink)
Member: 82132
Thanks Meter: 15
Gdfs is ok. Flash phone solved problem 100%.
Old 07-06-2008, 02:33   #7 (permalink)
Member: 201816
Thanks Meter: 6
Thank you to all for help.
Phone solved.
Just full flashed and then I downloaded the rest file and unlocked again.
Now phone is working.
Thanks to all!
Old 11-14-2008, 14:13   #8 (permalink)
Member: 380511
Thanks Meter: 20
k550i cid 52 gdfs startup fail plz help me sir
Old 11-15-2008, 09:00   #9 (permalink)
askaralikp's Avatar
Member: 690456
Sonork: 1587650
Thanks Meter: 117
plz flas in ub insert at last verttion
Old 11-30-2008, 13:37   #10 (permalink)
chandio_180's Avatar
Member: 602248
Thanks Meter: 69
can u post reset files
thanks
.: Nokia N70 Dead Pls Help :. billal1050 Nokia Hardware & Hardware Repair 2 03-17-2009 10:53
kill my phone after unlock... pls help senkron24 BB5BOX 4 02-16-2008 09:30
K750i dead while unlocking Pls Help me. unitedtelecom Cruiser Suite 4 12-26-2007 12:54
K750i dead while unlocking Pls help unitedtelecom Cruiser Suite 2 12-26-2007 12:30
n70 DEAD while flashing pls HELP! Urgent 1max Nokia Base Band 5 ( BB-5 ) 3 09-04-2006 20:10
Page generated in 0.23952 seconds with 10 queries
