Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
02-27-2010, 12:58 | #6 (permalink) |
Freak Poster Join Date: Oct 2007 Location: indonesia Age: 42
Member: 602540 Status: Offline Thanks Meter: 20 | @hahidmobiles : Seems like never bro.. red blinking never can be solved by just flashing the phone. write GDFS is recomended. @Binoy : Try to use USB cable bro, or try it with another box. if its the same, change charging connector n check for charging ways |
02-28-2010, 13:26 | #10 (permalink) |
Junior Member Join Date: May 2009
Member: 1033062 Status: Offline Thanks Meter: 1 | Dear people. Attach a charger; if the charging indicator LED is blinking only approx. 4-7 times before it stops, the problem is caused by software! Also continuously red blink duo to battery need charge. Important: You might have to try attaching the charger up to 5 times in order to be sure you don’t have symptom. IF THE UNIT’S CHARGING INDICATOR BLINKS ONLY APPROX. 4-7 TIMES YOU SHALL NOT REPLACE ANY COMPONENTS! The problem is caused by corrupt software. IF THE UNIT’S CHARGING INDICATOR BLINKS APPROX. 1-3 TIMES, GDFS OR HARDWARE PROBLEM. Press thanks button if it helped you. Last edited by nfs__; 02-28-2010 at 13:33. |
Sony ericson w705 redlight blinking | ArtC | Sony Ericsson Hardware Repair | 1 | 09-11-2009 17:08 |
k-800 redlight blinking cid49 | ahamed imran | Sony Ericsson Hardware Repair | 6 | 01-11-2009 19:50 |
sucessfully repair k800i cid53 redlight blinking | jatchaminda | DreamBox | 0 | 08-26-2008 13:26 |
Can repair w200i redlight blinking??????? | saajith | DreamBox | 5 | 07-02-2008 14:30 |
K800i redlight blinking | celluniversal | Universalbox | 1 | 03-08-2008 09:43 |
