Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: iran-kashan Age: 33
Member: 157053 Status: Offline Thanks: 145
| Last Solution For K800 Keypad Problem Hi For K800 That Key Pad Are Not Good Working For Example When Push 9 Phone Power Off 1-check Uif 2-check Uif Connector 3-check Volume And Power Key 4-last If Pereviuse Step Dosent Help (((change Cpu And Then Unlonk (5lock) With Tp ))) Dont Forget Click On Thanks Bottom |
| The Following 38 Users Say Thank You to morteza-icu For This Useful Post: | andhufazil, ansari.behnam, BATAK, cdma_gsm, cryptopsy, davi yong, didi8321, djems, ESM_GSM, farzadarian, fatix_cell, gavad700, hooshmandnia, Ibmboxer, ibrahim9, jeeranajee, jln310, kashifbmz, kj79, libra_13, mammadsayfee, masoud ehsan, MN110, mr.6630, musa_bahi, nokia3250mrh, sadiq123, srmd, stlee, suzani3, termis_shadow, unlockcelucar, valtersaaltersa, vasimj, VUKASIN, w850, yonasmobile, ~The JoKeR~ |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2007 Location: kuwait
Member: 439853 Status: Offline Sonork: 10011444558887 Thanks: 2
| please help k800i always k800 handfree mode, ![]() |
| The Following 3 Users Say Thank You to shamveelahmed For This Useful Post: |
| | #3 (permalink) |
| 1-check charge connector 2-check mic ic and replace 3-click thanks bottom |
| The Following 13 Users Say Thank You to morteza-icu For This Useful Post: |
| | #4 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2001 Location: PL Age: 30
Member: 5268 Status: Offline Thanks: 1
| Quote:
2nd We all know how to read service manuals. So that's not needed to place obvious things here. 3rd No need to push "Thanks" or write "Thanks" :P BR | |
| The Following 7 Users Say Thank You to ceedee For This Useful Post: |
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007
Member: 587516 Status: Offline Thanks: 35
| sir how can i connect the keys 4 7 * 9 sir!! i checked the lines, it is connected!! please help sir!!! |
| The Following User Says Thank You to shadowdex For This Useful Post: |
| | #6 (permalink) |
| Junior Member ![]() Join Date: Aug 2006
Member: 333017 Status: Offline Thanks: 1
| If the keyboard port of the processor is punched. On non working line to connect power from a power supply unit and step-by-step to lift while sharply the current drain will not fall. chances 50 on 50 or dies CPU or will earn line |
| The Following 2 Users Say Thank You to axel80 For This Useful Post: |
| | #7 (permalink) |
| Junior Member ![]() Join Date: Jan 2009
Member: 957701 Status: Offline Thanks: 2
| PLZZZ!!!! help me too found k800i key problem 1,6 & 3 not working. And when also we touch 3 than apper sutdown option. The "Volume UP" doesn't work, what we should do ? |
| The Following 2 Users Say Thank You to lascoman007 For This Useful Post: |
| | #9 (permalink) | |
| Quote:
just change CPU, 100% tested, also try to burn, for that connect (-) to key "3" and (+) to ground, from power supply unit 2A at 3-4 Volt, ESD protection in CPU can be burned | |
| The Following 3 Users Say Thank You to axel80 For This Useful Post: |
| | #10 (permalink) | |
| Quote:
, can you please direct me to this illusive "CPU" is it D2000 or N2000, how should i proceed? should i resolder? or a reflow should solve it? ![]() Thank you for your contributions | |
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2009 Location: bangladesh_ sylhet_ biswanath Age: 28
Member: 1033714 Status: Offline Sonork: 1615102:md Thanks: 87
| k800 keypad problem 123789 vol up donot work plz quick help anyway ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| The Following User Says Thank You to mothertelecom For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| K800 keypad problem any salution | pkghosh1 | Sony Ericsson Hardware Repair Area | 17 | 07-25-2011 08:54 |
| K800 keypad problem | emilio | Sony Ericsson Hardware Repair Area | 15 | 08-12-2010 11:36 |
| solution for 7610 keypad 100% problem | DIGITAL BABU | Nokia Hardware & Hardware-Repair Area | 48 | 06-29-2010 11:26 |
| solution for n95 keypad problem | electrosoft | Chinese Models & Cloned Phones | 0 | 05-06-2009 08:59 |
| Need Solution For N90 Keypad Problem | miecom | Nokia Hardware & Hardware-Repair Area | 6 | 06-23-2007 10:53 |
