Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
03-22-2010, 02:28 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: kamp_kodo, manado INDONESIA
Member: 1000685 Status: Offline Thanks Meter: 156 | lcd light solution and sim patch gen tools 4shared.com - online file sharing and storage - download Sim lock Patchgen.rar 4shared.com - online file sharing and storage - download Sony Ericsson repair light display.exe How use sim lock : Use of SIMLockPatchGen Press the select firmware button and browse for your main firmware file. Press make patch. Now you will find folder with the name vkp and in it you will find your generated patch file. Use of AnyCID: 1) use mkrest to make rest for your fw 2) extract contents of {yourplatform}.zip and {yourphone}/{firmware}.zip to your phone 3) turn your phone on and run games/executor 4) reinsert battery db201 x: 5) start jdflasher, select right script (don't forget to edit cid num value in it), uncheck " rsa" box, connect, enter to bflash 6) flash rest 7) do whatever you want continue from the step 3 further bfs doesn't work db2020 : 5) make quickaccess patch using qamaker 6) start jdflasher, select qa2020. xml, connect, enter to bflash directory (use updated qa2020. xml) 7) flash rest 8) flash quickaccess patch 9) do whatever you want use qa2020. xml further |
nokia 6120c keypad and lcd lights blinking and dim | qureshi7 | Nokia Hardware & Hardware Repair | 4 | 07-24-2013 07:02 |
N95 8gb no lcd and lcd light solution | jhoesteve | Nokia Hardware & Hardware Repair | 25 | 01-21-2011 17:37 |
k500 k500i k700i lcd lights solution and jumper by alex | ali-xander™ | Sony Ericsson | 0 | 11-29-2009 02:58 |
V3i No Keypad and LCD Lights Solution | 2lits | Motorola Hardware Repair | 5 | 10-14-2009 13:30 |
need 6260 lcd light solution | erkan06us | Nokia Hardware & Hardware Repair | 10 | 07-09-2009 18:11 |
