Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
11-23-2007, 01:46 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | Mic problem.... hello... I have some problems with mic on w300, z550, and z520.... the mic its too low.... and changed mic for samsumg s300 and continue too low.... some solution... |
03-27-2010, 13:06 | #4 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 408989 Status: Offline Thanks Meter: 21 | Actually maf2ir meant you have to put jumpers between the mic's connector and the new mic, that's all ! Not to say you're less smarter but sometimes there's no need people to do everything for us. Just like somebody has digged a well for you and now it's time for you to find a way to get the water from the well. -- Main Point -- As Maf2ir said he uses w850 mic but not work for me, i used nk 5300 mic. Because 5300 mic gave me higher kilo ohms, so it worked. Original w300,z520, k610 etc uses ~1.17 - 1.19 kOhms, w850 uses ~1.6 kOhms, 5300 uses ~2.2 kOhms mic. As my experience told me higher ohms mic will get more louder. |
07-23-2011, 14:30 | #5 (permalink) |
Freak Poster Join Date: May 2008
Member: 767784 Status: Offline Thanks Meter: 21 | mic yes my friend u r right. as i am trying to say to put with jumper becoz some time dust come in side the connection.and as i suggest w850 mic becoze w850 mic is smaller then 5300 mic so it can be easy to fit in all places and if u have big place then u can use 5300 mic no problem thanks any way. |
5310 mic problem . changed mic 5 times | TRABEL | Nokia Hardware & Hardware Repair | 4 | 06-17-2009 13:33 |
samsung c130 mic problem changed other mic | WHED | Samsung Hardware Repair | 0 | 04-30-2009 12:43 |
j300 mic problem i change new mic but same | shani72 | Sony Ericsson Hardware Repair | 1 | 03-25-2009 07:00 |
c5000 china mic problem i chang new mic butt same | shani72 | Chinese Models & Cloned Phones | 1 | 03-22-2009 08:10 |
K800i mic problems. Sw and 2 replacement mics, still no go | dissonant | Sony Ericsson Hardware Repair | 0 | 05-09-2008 03:38 |
