Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
09-21-2007, 23:29 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 593016 Status: Offline Thanks Meter: 0 | my w810i is crazy. Last week I bougth a W810i with WSOD , so I have written the las FS ( european1 ) and fake Main, I have copy the customization with Far and Flash the last Main available. Ok, it seems to work, when I switch on the phone it works. The problem is that after several hours ( its random, sometimes 2 hours sometimes 30 hours ) , the phone switch off itself. There is no way to switch on the phone, even removing/inserting the battery it doesnt power on. Connecting it to the DCU-60 cable is not recoginized by the computer. Using the service cable ( TMS ) I can connect with XS++ and write a new firmware , but still the phone is dead. The only way that I have found to power on is connecting it to the DCU-60 cable and wait ( sometimes 30 minutes , sometimes 1 hour ). When the mobile swith on , all work again, I have tried to write several firmwares but always the same. Even if I swicth the phone in walkman mode it switch off after 2 or 3 hours. I think that I have tried all!!! , I have use SEMC , GOT ( buying credits ) and its the same, the problem remains. Its very rare because when the phone is working all its ok, I can speak with it , use bluetooth , walkman etc etc. Any idea about what can I do ? BTW I have tried to send the w810gdfs.gdf with SEMC 8.4 but I always get the error 301803 Thanks a lot. |
09-22-2007, 09:47 | #2 (permalink) |
Freak Poster Join Date: Mar 2006 Location: In a house Age: 46
Member: 249757 Status: Offline Sonork: 100.1601084 Thanks Meter: 117 | You mite have dry joints beneath ur CPU, try reworking it, but do it carefully. If you dont do it properly u will kill ur phone permanantly. I had the same problem with a J300, Did software, phone still dead. I reworked CPU, and then it worked. |
09-22-2007, 22:00 | #5 (permalink) |
Member: 593016 Status: Offline Thanks Meter: 0 | No, I have not tried with setool , only with SEMC , XS++ and GOT. Ok , I have tried now with setool2 lite, First I have written the gdfs file , select the .bin in misce and Write GDFS , it seem to work ok ( with SEMC always I got an error ) : Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35906300..... CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: R4CE012_CXC1250316_GENERIC_HN Restore from:R4CE012_CXC1250316_GENERIC_HN Setting up GDFS... format gdfs complete. will write 1110 variables done Phone detached Elapsed:69 secs. --------- I have tried to switch on the phone , but nothing happen now is dead ( I will need connect it to the DCU-60 cable for 30 minutes if I want to be able to power on ). Ok , I will flash it before connect to the DCU-60 with setool2 , add the MAIN and FS to the list, and .zip custom packet on the misce and : FILE RECOGNIZED AS CUSTOMIZATION PACKAGE. CDA:CDA102494/108 MODEL:W810i VARIANT:EUROPE_1 LANGUAGE: EN LANGUAGE: PT LANGUAGE: ES LANGUAGE: FR Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35906300..... CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: R4CE012_CXC1250316_GENERIC_HN Restore from:R4CE012_CXC1250316_GENERIC_HN writing D:\Hack\GSM\Ericcson\W810\Firmware\W810_R4CE012_MA IN_GENERIC_HN_RED49.mbn CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:342 Will flash 342 blocks... SSW loading returns:0 writing D:\Hack\GSM\Ericcson\W810\Firmware\W810_R4CE012_FS _EUROPE_1_RED49.fbn CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:157 Will flash 157 blocks... SSW loading returns:0 Elapsed:585 secs. It seems to work perfect, I see that the CDA of the phone is different of the custom package, because if I push the Identify button I got : Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:359063006..... CERT:RED FLASH CID:49 COLOR:RED MAPP CXC article: R4DB005 prgCXC1250316_GENERIC_HN MAPP CXC version: R4DB005 Language Package:S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 Operator: 000-00 USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed:7 secs. The cda of custom package was CDA102494/108 instead this, and is normal the Operator to : 000-00 ? I have changed the CDA with SEMC and now if I push identify I got the right CDA : Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:3590630.... CERT:RED FLASH CID:49 COLOR:RED MAPP CXC article: R4DB005 prgCXC1250316_GENERIC_HN MAPP CXC version: R4DB005 Language Package:S_ASIA_LEVAN CDA article: CDA102494/108 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 Operator: 000-00 USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed:2 secs. BTW what is : RESTORATION FILE PRESENT FOR DETECTED FIRMWARE ???? Anyway the phone is still dead, I will connect to the DCU-60 cable and wait..... Thanks a lot. |
09-23-2007, 20:22 | #6 (permalink) |
Member: 593016 Status: Offline Thanks Meter: 0 | No luck with SE Tool2 lite, there was no error writing the GDFS , when finished the phone was dead (nothing happen when power on ) connected to the DCU-60 cable in 30 o 40 minutes its alive, and I see the screen "file transfer ..." , I didnt touch nothing and in 2 hours freezes |
my box is crazy pleas help me | hihisoft | BB5KING for (BB5BOX) | 2 | 11-18-2008 01:29 |
my w810i is dead | gsmcozumel | Sony Ericsson | 1 | 01-04-2007 23:00 |
My 6630 going crazy after UPGRADE | dannystwo | Nokia Base Band 5 ( BB-5 ) | 8 | 10-04-2005 09:26 |
my s35 gone crazy after upgrade from v18 to v25 | mandzo | x1x to x45/x50 | 1 | 06-08-2003 08:15 |
