Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 03-14-2010, 12:02   #1 (permalink)
Member: 719399
Thanks Meter: 228
C905 vibrating alert
Hi everyone
I have se c905 and the vibrating alert is not working.
Do you know how to fix it?
Exchange the vibrator or?
Old 03-14-2010, 14:59   #2 (permalink)
pavithra_uk's Avatar
Member: 1142667
Thanks Meter: 16
check contact of vibrator. remove vibrator and test it with 3V (two AA battery or phone battery)
The Following User Says Thank You to pavithra_uk For This Useful Post:
Old 03-14-2010, 20:17   #3 (permalink)
Member: 719399
Thanks Meter: 228
The motor is working. Tested with phone cell.
But overall vibrating alert is not working. What's wrong?
Old 03-14-2010, 22:12   #4 (permalink)
Member: 719399
Thanks Meter: 228
Now, when I turn on the mobile it vibrates which is good. But the lcd display has broke...Will replace the lcd and post the result.
Thanks
Old 03-15-2010, 09:24   #5 (permalink)
Member: 1142667
Thanks Meter: 16
Thanks
is your LCD damaged ? otherwise it may be software fault. (like K850 BROD)
Old 03-16-2010, 16:22   #6 (permalink)
Member: 719399
Thanks Meter: 228
Hi
Replaced lcd but the problem still persists. When turn on the mobile it looks like the display is very dark.
Old 03-17-2010, 17:29   #7 (permalink)
Member: 719399
Thanks Meter: 228
Reflashed the phone and lcd display is still too dark. I found that ther might be sth wrong with the coil beside battery.
Old 03-18-2010, 17:12   #8 (permalink)
Member: 1142667
Thanks Meter: 16
CHECK MAIN FLEX, IF FLEX DAMAGED BACKLIGHT WILL NOT WORK.
ALSO CHECK
LCD CONNECTOR
CHECK LCD BACKLIGHT LED DRIVER.
did you heared startup sound ?
Old 03-19-2010, 01:02   #9 (permalink)
Member: 719399
Thanks Meter: 228
ALSO CHECK
LCD CONNECTOR
No, I haven't heard any sound. You think that's the flex(but which one?-the one that goes from keypad membrane to the main board.
I've already checked the flex that goes from keypad to the top of the phone.
So maybe that flex that goes to the board.
Lcd connector is good, I have no doubt.
LED Driver?
Thank you for support
Old 03-19-2010, 01:42   #10 (permalink)
Member: 719399
Thanks Meter: 228
Maybe that's faulty Sony Ericsson C905 LCD flex ribbon
Old 03-19-2010, 16:30   #11 (permalink)
Member: 1142667
Thanks Meter: 16
LED Driver?
hey, check main flex cable (connect with main board)
check TP4200 voltage (V4201 anode voltage) it must be lager than battery voltage. may be 12~16V
If you didn't hear startup sounds, I suspect phone may not turn on correctly. what happens if it connect to computer?
Old 03-20-2010, 10:58   #12 (permalink)
Member: 719399
Thanks Meter: 228
Hi
I ordered the flex that goes to the main board and see what happens.
I flashed the mobile so detects fine.
Thank you for help
Old 03-20-2010, 12:26   #13 (permalink)
Member: 1142667
Thanks Meter: 16
Hi
Thank you for help
also check LED driver output voltage as I given above post. do you have a schematic of C905?
Old 03-22-2010, 19:46   #14 (permalink)
Member: 719399
Thanks Meter: 228
Hi
I replaced the Flex but the screen is still dark.
Just bought the c905 faulty one so I'll replace the whole mobo.
Old 03-23-2010, 05:45   #15 (permalink)
Member: 1142667
Thanks Meter: 16
Hi
C905 is one of the SE's worse phone ever made. every phone had its own fault.
replace whole mobile if you can. or if can find another C905, you can check your motherboard with it. dark screen can cause due to lot of faults
LCD
Upper keypad flex
Main Flex
Motherboard (LED driver etc..)
Software fault (GDFS fault etc..)
did you get new one or used one ?
don't buy this crappy phone again.
In here (SriLanka) new C905 price = 600+US$ and used one going for 200$ or less.
sorry about your phone.
need c905 ringer ic jumper chand_gee Sony Ericsson Hardware Repair 4 11-26-2010 14:56
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] jus_chillin Cyclonebox 19 03-29-2010 11:57
Casio G-LIDE Tide Graph Vibration Alert Digital Mens Shock Resistant Watch IPMART ipmart WebShop 0 06-08-2009 12:20
nokia 3100 not vibrating alert abdone Nokia Digital Core Technology 4 ( DCT-4 ) 2 10-04-2006 03:51
no vibrating alert on T28 after falling down HELIOSS_RISALA Old Ericsson Phones & Sony Phones 6 09-06-2001 17:20
Page generated in 0.24282 seconds with 9 queries
