Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
03-08-2005, 10:40 | #1 (permalink) |
Insane Poster Join Date: Feb 2005 Location: Bulgaria Age: 54
Member: 113146 Status: Offline Thanks Meter: 2 | p900 no charge between connector for charger have a short circuit.something ideas for this? |
08-16-2006, 20:40 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | can you explain some thing on this picture..........? do we need to change this ic........... or just remove.........../? make it bit clear..................! |
08-23-2006, 13:19 | #5 (permalink) |
Insane Poster Join Date: Jul 2004 Location: lahore+bradford
Member: 74239 Status: Offline Thanks Meter: 0 | sloution 1st of all check urs p900 charging conector with meter if both charging conector shows short (joint)then no need to change charging ic.u need to change 1 smaal ic which is on the top of board near blututh indicator (3 leg ic)ur phone will b fixx.sory 4 my bad engligh. |
08-28-2006, 18:39 | #6 (permalink) |
Junior Member Join Date: May 2006
Member: 269426 Status: Offline Thanks Meter: 1 | p900 charging way heres the solution for ur p900 not charging! just link this 2 points and thats it. p900 optimized charging!!! |
The Following User Says Thank You to djabroni For This Useful Post: |
07-09-2010, 12:10 | #9 (permalink) | |
Freak Poster Join Date: May 2007
Member: 499081 Status: Offline Thanks Meter: 44 | Quote:
this solution works fine on not charging but it causes earpiece to stop working.tried on two sets result earpiece not working.i need help to fix earpiece.tnx | |
p900 no touchscreen and no led | baber2000 | Sony Ericsson Hardware Repair | 0 | 02-10-2009 19:32 |
p900 no charging indicator | shadowdex | Sony Ericsson Hardware Repair | 1 | 07-08-2008 17:30 |
p900 can't charging, | genocite | Sony Ericsson Hardware Repair | 14 | 03-26-2007 03:45 |
P900 no mic no speaker | ByMinsk | Sony Ericsson Hardware Repair | 6 | 12-28-2006 23:18 |
plz help p900 no signal, no access to network.... | sniper01 | Sony Ericsson Hardware Repair | 0 | 09-05-2006 06:43 |
