Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
09-12-2009, 12:50 | #1 (permalink) |
Junior Member Join Date: Jun 2006 Location: Syria
Member: 293097 Status: Offline Thanks Meter: 0 | plz help k770 another application is running close it then start the camera |
09-15-2009, 07:49 | #5 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Bolton Age: 44
Member: 41976 Status: Offline Thanks Meter: 33 | hi! its not 100% hardware. you could try to flash it first.the best thing is to flash with a higher version than it is already. if still not work then try to locate camera driver ic and change it. good luck! |
The Following User Says Thank You to wearephones For This Useful Post: |
12-27-2010, 17:34 | #7 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 223818 Status: Offline Thanks Meter: 31 | k770 another application is running close it then start the camera change k770 keypad flex cable ( idid not test it but ihave read it in another forum they said tested and worked fine) |
12-27-2010, 17:49 | #8 (permalink) |
Member: 223818 Status: Offline Thanks Meter: 31 | also ifound this in another site which sell Cell Phone Spare Parts: You are Bid for the Keyboard Flex Cable Ribbon for Sony Ericsson K770i ~! Item Description: This ribbon connects the Keypad & the main motherboard together. It may helps you to repair your phone with following common faults: - LED Problems - Camera Problems - Keypad Problems so ithink its like other guys said |
550i "Another application is running close it and then start the camera" | pakmobiles | SETool2 | 3 | 05-21-2011 08:27 |
solution for camera K770 "Another application is running.Close, then start the camera | khassene01 | Sony Ericsson Hardware Repair | 4 | 05-20-2010 02:32 |
w850i another application is running close it.and then start the camera help | pakmobiles | Sony Ericsson | 1 | 09-13-2009 20:26 |
another application is running,close it then restart the camera | Ehsan_shariat | Sony Ericsson Hardware Repair | 9 | 08-29-2009 16:40 |
K770 another application is running | algeriano_19 | Cruiser Suite | 2 | 07-07-2009 09:10 |
