Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
12-07-2009, 18:17 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: portugal Age: 41
Member: 12340 Status: Offline Thanks Meter: 2 | [Problem] c905 no wifi a c905 stay always looking for wifi. what i already did: - connect manually: not work - Upgrade last software: not work - remove memory card : not work - repair gdfs: not work - Checked antena connection: not work any sugestion? thank you |
12-29-2009, 05:45 | #4 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Quote:
No he does not need to downgrade. | |
03-18-2010, 05:20 | #9 (permalink) |
Freak Poster Join Date: Aug 2008 Location: 100 islands philippines.....
Member: 850153 Status: Offline Sonork: 02123455 Thanks Meter: 138 | just to update this thread,,any solution for c905 wifi problem! i have the same problem also.any one who had been tried a working solution,,pls. do help us! |
04-10-2010, 15:26 | #10 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Macedonia
Member: 303652 Status: Offline Thanks Meter: 35 | @.:SUBRATA:. I am not able to connect WiFi anymore. The Mac address is showing: 00:00:00:00:00. Customer said it was working fine till some days ago. I already tried upgrade the software, but the problem stills there. Also i change upper keypad-flex and all is the same. Which script is that you said? I cannot find it on suport forum you said. Or i want to change gdfs it might be a problem Last edited by kosturon; 04-10-2010 at 15:33. |
05-20-2010, 06:37 | #12 (permalink) | |
Member: 319447 Status: Offline Thanks Meter: 4,949 | Here you go guyz Save the below code as customize_upgrade.xml using notepad. Use fsmanager script to access phone's filesystem. Copy to tpa/preset/custom. WiFi should now be fixed. Quote:
The Following 2 Users Say Thank You to .:SUBRATA:. For This Useful Post: |
Iphone 3g no imei,no wifi,no modem firmware,no bluetooth | mohsin27aug | iPhone 4 / iPhone 4S | 10 | 10-10-2011 08:35 |
c905 no network flash problem Shinobu_TA.ssw | karamusa | SETool2 | 7 | 04-24-2011 14:20 |
iphone 2g problem with wifi no wifi | uburo22 | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-16-2009 22:03 |
2g iphone wifi no wifi | mahavir_compu | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 11-13-2009 08:13 |
Iphone 2g no wifi, wifi address N/A solution needed Iphone experts!!! | lasty | iPhone 2 / iPhone 3G / iPhone 3GS | 5 | 05-17-2009 08:34 |
