Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 11-23-2002, 18:34   #1 (permalink)
Member: 17896
Thanks Meter: 2
R320 dead
I have a R320 dead. I can write eeprom to phone, and try to write flash to phone, but when flash write 99% - ATR v5.3 program stop,and i read on screen ERROR03.
After that phone is no charging, no power on.
Any solution?
Old 11-23-2002, 23:06   #2 (permalink)
Crazy Poster
Member: 17649
use charged battery
try other cable
with t28 on such case i change eeprom or use ponyprog
Old 11-24-2002, 08:56   #3 (permalink)
Member: 17896
Thanks Meter: 2
Battery voltage is 4.06 V.
Cable is okey, becase I can write eeprom to phone,also I try to flash another phone and all was ok.I use Varanius 1.0 and ATR service 5.3.
Zab4o
Old 11-24-2002, 11:58   #4 (permalink)
Crazy Poster
Member: 17649
error03 - wrong flashfile size, wrong battery.
for ATR use *.sbn
for Varanius - *.bin flash image.
take ANOTHER charged battery.
better higher capacity.
Old 11-24-2002, 14:01   #5 (permalink)
Member: 17896
Thanks Meter: 2
Thanks for solution,
I will try to flash it with another flash file, maybe this one is bad. I will try this tommorow at work.
I try with varanius v1.0, i try to flash it like t28, cause I don't have r320 option aviable, it only erase flash and don't write new one flash, so I try to flash with ATR and everything was ok, till 99% of flashing, it stopped and writes error03.
Old 11-25-2002, 20:18   #6 (permalink)
Member: 17896
Thanks Meter: 2
Today I try with another flash, and other battery, but the results is the same.I think that there is something wrong around Supply IC or LF IC?Is anybody have similar problem?
Old 11-26-2002, 05:57   #7 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Pfu... only flashing is wrong, and in most cases problem is battery level - take few batterys from T28/t29/R320 ect... with different voltages (i think that you must use very low voltage) and try again, try also Varanius for flashing or special 320 version of Datex ATR SW
Debelia Mark
Old 11-29-2002, 22:29   #8 (permalink)
SPUnlock_SK's Avatar
Member: 13922
Thanks Meter: 334
change EEPROM and reflash
Old 11-30-2002, 07:09   #9 (permalink)
Member: 683
Try older ATR 5.1
Old 11-30-2002, 09:23   #10 (permalink)
Member: 17896
Thanks Meter: 2
Tnx guys,
I repair my phone after changing eeprom and then flashing.
Wishes,Zab4o
R320s Dead BarCoder Old Ericsson Phones & Sony Phones 9 12-14-2002 08:49
Dead R320s Pets Old Ericsson Phones & Sony Phones 1 01-21-2002 23:33
R320 dead!!!! bluelights Old Ericsson Phones & Sony Phones 1 09-26-2001 00:17
R320s dead after flash to be1(ORIG)... Baza Old Ericsson Phones & Sony Phones 3 05-25-2001 13:44
Dead R320s free_gsm Old Ericsson Phones & Sony Phones 4 12-21-2000 01:08
Page generated in 0.16558 seconds with 9 queries
