Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 08-21-2008, 18:56   #1 (permalink)
Cheater -Don't Deal with him-
Member: 644786
Thanks Meter: 2,166
Repair Information Document Listing By Sonyericsson
V640/K630 Audio Issue (Buzzing Noise)
Problem
Buzzing or Crackling sound heard from the receiver during call.
The problem is also caused when the charger is inserted to the phone when placing call.
Root Cause
The Root Cause of the issue is from SMT production, during the screen printing of solder paste not enough has been applied to Mic PCBA pads, therefore causing dry solder joints that creates the buzzing sound under certain conditions.
Unclear of how many affected units due to unclear production weeks are affected, units we have received so far were produced WK816
Solution
Remove B3100 Mic add solder to PCBA Mic pads then re-solder B3100 Mic.
Retest the Mic and verify if its working from service menu tests and live call.
SMT production have been informed to tighten there process for screen printing.
Reference number: 16491-71759
Created: 2008-08-21
The Following User Says Thank You to SEMCSEC For This Useful Post:
Old 08-22-2008, 11:53   #2 (permalink)
Member: 644786
Thanks Meter: 2,166
W380/Z555, Display Problem UPDATED
This document is applicable for W380 and Z555
Introduction
If a customer returns a phone (W380 or Z555) due to a problem with the main display, one possible cause is a damaged main LCD flex that is shorting against the metal frame of the upper front cover.
Solution
In the process of addressing the inner display problem, if the step is reached in the troubleshooting procedure to replace the Upper Front Cover assembly (This assembly contains the inner display) add the Protective Plate Tape to eliminate the risk of the LCD flex shorting to the metal frame.
NOTE!
If the upper portion of the phone is disassembled for any reason, you should check for the presence of the Protective Plate Tape. If Protective Plate Tape is not present it should be added. Even if the LCD flex does not appear damaged, add the Protective Plate Tape to eliminate the risk of the problem arising later and causing a re-return.
Refer to the Mechanical Working Instructions of each model, for detailed instructions on proper placement of the Protective Plate Tape for that model.
Reference number: 16519-71664
Created: 2008-08-21
The Following 2 Users Say Thank You to SEMCSEC For This Useful Post:
Old 08-22-2008, 11:55   #3 (permalink)
Member: 644786
Thanks Meter: 2,166
New SERP Release 1.9.06
This document is applicable for SERP Users
Introduction
A new release of SERP is available for download from CSPN
Reason for change
• Added support for the following new products: C902c, W760c, G700c, R300i, R300a, Z250a, W980, TM506
• Added support for the following new TAC’s: 35651402 (W580), 35653202 (W200a), 35379802 (C902c), 35441202 (W760c), 35706702 (W760i), 35648302 (W760i), 35648302 (W760i), 35551802 (Z320i/Z320c), 35389002 (G700c), 35452502 (R300i), 35457202 (R300a), 35552002 (Z250i/Z258c), 35934701 (Z250a), 35623702 (W350a), 35535302 (W980), 35726402 (W580im), 35739202 (W910i), 35726602 (W580), 35726502 (W580), 35726202 (TM506), 35714902 (C902), 35507602 (TM506), 35698302 (TM506)
Fixed a SW bug in the Z250 and Z320 GNG routines.
Comments
Please download and use.
This information is provided by:
Customer Services
Sony Ericsson Mobile Communications AB
Reference number: 16485-71757
Created: 2008-08-21
Old 08-22-2008, 12:11   #4 (permalink)
Member: 644786
Thanks Meter: 2,166
SI – Update “Use DCU-65 instead of DCU-60”
Affected products:
DCU-60
Description:
This SI is an update/clarification on the SI 16248-69241.
It has been discovered that the DCU-60 is not really speed compliant. This may effect performance and potential fails while flashing a product with Emma.
To be on the safe side and simplify the message, it is recommended that no matter which product platform, (that use USB) Service Centres should ONLY use the DCU-65 cable (RPM13112).
DCU-65 has got 2 "big bubbles" on the physical cable. These "bubbles" are de-coupling devices to remove interference. The DCU-65 cables are a bit shorter than the DCU-60 cables.
Old 09-04-2009, 21:49   #5 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
Introduction
Reason for change
Comments
Customer Services
Created: 2008-08-21
pls give the link for this useful information
sajidmirza
Old 09-10-2009, 01:37   #6 (permalink)
electrosoft's Avatar
Member: 93850
Thanks Meter: 48
Introduction
Solution
NOTE!
Created: 2008-08-21
Hi
after changing flex and display problem not solved. solution is to remove the small lcd
br!
The Following User Says Thank You to electrosoft For This Useful Post:
Software Document Listing By SonyEricsson SEMCSEC Sony Ericsson 20 04-29-2017 10:00
E8 Bootloader Compatibility & Repair Information green bird MSS Box II 12 09-10-2011 00:05
Repair Information System Software a4tech Universal GSM Software 6 08-20-2006 03:08
repair information for Sam E800 gsm40 Samsung Hardware Repair 0 11-05-2004 14:44
Document listing for every GSM Phone made to date jbes Wanted Products 2 05-07-2004 10:20
Page generated in 0.20332 seconds with 10 queries
