Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
11-20-2016, 17:17 | #1 (permalink) |
Junior Member Join Date: Jun 2005 Age: 35
Member: 153858 Status: Offline Thanks Meter: 1 | request m4 aqua pinout slot sd I expose my question / problem I have a Xperia M4 Here model E2403, which does not recognize the SD card, when disassembling and desoldering the SD full slot, I see that I have a welding in bad condition, corresponding to the pinout CLK of the SD card, well, having that pin - soldering bad, I wanted to bridge to the pin or output that has that exact point to re-solder and to recognize the sd card, to see it, are many welding points to check, but since I have no anchorage to check with a multimeter, I have Hence my question I have been looking in other forums where normally published ways or pins of other models, but with this, I believe my knowledge, which I have not had the luck to do. So I ask you a little help to find such a solution that in other models has been wonderful Here I leave a link of the image at the macro level, but a little badly made of the plate in question, on the side of the SD slot |
11-21-2016, 14:33 | #3 (permalink) |
Member: 153858 Status: Offline Thanks Meter: 1 | Hi, I have already found several pin-ways SD slot model E2303, since there is no web that quotes and verify this, I publish it Of the 8 pins/ways I found, 6, missing DAT0 and DAT1, in the image did not indicate GND, since any point of plate is gnd as you know. regards |
The Following User Says Thank You to cristl For This Useful Post: |
