Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-14-2010, 15:09   #1 (permalink)
Member: 563368
Thanks Meter: 4
s312 only keypad led blinking
i have s312 which is water damaged one, i have cleaned board with IPA,after that when i try to on only keypad led is blinking there is no display please help me anyone. thanks in advance
Old 05-21-2010, 05:35   #2 (permalink)
Member: 258092
Thanks Meter: 11
i have 1 s312 same problem with your
water dmg , clean the board , only keypad light are shows up when turn on , can't make call , no sound , and it will turn off after few seconds ,
when i insert usb port want to flash the phone , the keypad led will shows up
and can't even flash the phone or indentify the phone
anyone help?
Old 05-22-2010, 06:43   #3 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
(lesyid + Turks) both try to flash,,,,,,,,,,,,
The Following User Says Thank You to gsmshare For This Useful Post:
Old 05-24-2010, 05:41   #4 (permalink)
Member: 258092
Thanks Meter: 11
anyone help?
hope u see what i type there
Old 11-06-2010, 13:56   #5 (permalink)
Member: 463320
turks,i hv s312 same problem as u...how u fix it?
Old 11-19-2010, 12:31   #6 (permalink)
Member: 597974
Thanks Meter: 2
what i say is hardware problem but still finding a solution..
Old 11-29-2010, 07:08   #7 (permalink)
Member: 1352708
Sonork: asdfg
Thanks Meter: 3
power ic normal hit zzzzzzzz
Old 01-30-2013, 18:07   #8 (permalink)
Member: 1312432
Sonork: killcrc
Thanks Meter: 3
hi i have s312 set, problem is when i press power bottom just glow keypad & other not
hi
i have s312 set, problem is when i press power bottom just glow keypad & other not work, also try to flash but same problem.
any sugestion????
thx in advance!!!!!!!!!!!!!
Old 12-04-2013, 15:01   #9 (permalink)
chinnivardan's Avatar
Member: 892484
Sonork: not using
Thanks Meter: 916
any solution.............
Old 05-13-2014, 06:01   #10 (permalink)
Member: 1952631
i have 1 s312 same problem.......
Blue LEDs in your Display SUPER! GM Nokia Hardware & Hardware Repair 0 06-25-2000 12:47
Only MAX232 ??? AMIGO Nokia Hardware & Hardware Repair 7 04-12-2000 09:41
blue led? Michael Go Wanted Products 0 09-10-1999 00:57
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.18014 seconds with 9 queries
