Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 10-04-2007, 07:39   #1 (permalink)
Member: 388978
S500 and W580 no power
I have two models S500 and W580 no power on. When i press the power on/off button, the led beside the flip is flicker. I measure the current when power on is about 0.07A but return to zero 0.00, immediately. Pls help me, i already removed the ic power, but the same. anybody help a good solution? thks
Old 10-06-2007, 05:57   #2 (permalink)
Member: 388978
nobody have the best solution?
Old 10-10-2007, 06:37   #3 (permalink)
Member: 388978
i had to try to run software, before change with new ic power, but not successfull. But i hope any pro have the best solution to help me!!!
thk a lot!!
Old 10-13-2007, 16:29   #4 (permalink)
Member: 608574
question for u lamborg: First, u said that u measured 0.07A during On State,meaning u can draw current but then it will drop to Zero? correct? secondly, when u run the software but not successful meaning u can "ABLE" to detect? Then it should nothing to do with the Power IC, am i correct?
Old 10-15-2007, 03:11   #5 (permalink)
Member: 388978
when i connected it to PC to run software ( EMMA, SE tool....) but it didn't detect. Special solution running in Emma software is SEPI cable, in this case it can detect the phone, but running about 49% failure. After do that, i changed IC power, but not power on.
Old 10-15-2007, 04:57   #6 (permalink)
Member: 608574
yeah i know the SEPI cable, but it has nothing to do with the power IC unless u check the VFLASH if correct or not...when it was detected using SEPI & failed on a certain percent meaning u have problems w/ the flash or RAM IC connections...whats the error show after failing anyway? failed identification????
Old 11-01-2007, 14:05   #7 (permalink)
Platijet's Avatar
Member: 26279
can you pls give me the SEPI cable pinout??? (old or new one)
Old 11-05-2007, 05:50   #8 (permalink)
Member: 388978
I had found the main cause of this problem. That is the IC flash failure. I had changed new IC, the power on. But not perfect, because the main board S500 and W580 very small and thin, it sometime auto off and white screen. Only one day to test it returned the same (oower off).
Any body have another soluton?? help me!
Old 11-23-2007, 13:41   #9 (permalink)
cellularry's Avatar
Member: 42276
I am facing the same problem with S500.
Did you find any solution to repair it.
Thank you
Old 09-01-2008, 21:44   #10 (permalink)
Member: 397056
any solutin? the same problem here! plz help
w580 no power on medagoga Sony Ericsson Hardware Repair Area 1 01-20-2010 21:55
W580 no power, press power on the red light blinking! lamborghini Cruiser Suite 20 05-20-2009 07:31
w580 no power after unlock richiehunter Sony Ericsson Hardware Repair Area 13 07-24-2008 09:18
3610 and 2100 no power problem... Abelardz23 Nokia Hardware & Hardware-Repair Area 0 09-17-2005 09:22
nokia 6210 charging all the time and 8210 no power on emmibox Nokia Hardware & Hardware-Repair Area 0 08-30-2001 05:46
Page generated in 0.28723 seconds with 11 queries
