Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
10-13-2012, 13:37 | #1 (permalink) |
Junior Member Join Date: May 2011
Member: 1577359 Status: Offline Sonork: gokul Thanks Meter: 0 | SE C510 internal antenna not detected A few days back , i tried to improve the signal reception of my SE C510 phone by connecting an external antenna in the external antenna socket of the SE C510, even after removing the external antenna , my signal is null and it shows " no network Coverage" . so i guess internal antenna is not detected. So can someone help me on this ...how to enable the internal antenna I have tried flashing the firmware, but it doesn't work Thanks in advance Regards, Gokul M |
10-20-2012, 08:05 | #3 (permalink) |
Member: 1577359 Status: Offline Sonork: gokul Thanks Meter: 0 | Hi satch1234, Thank you for your reply , I have heard about SW flashing and what is this GDFS repair ? Can u just explain me about this , and also please provide me the link to get this tool and the related files for this GDFS repair . thanks a lot again Expecting your kind reply Regards, Gokul M |
10-20-2012, 12:03 | #4 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Neverland
Member: 1005489 Status: Offline Thanks Meter: 105 | Quote:
You can't fix it without professional tool.Take the phone to some private unlock/repair shop.If you didn't damage hardware in that phone including antena cable and if it was not water damaged then gdfs repair should solve your problem. Good luck, Satch | |
The Following User Says Thank You to satch1234 For This Useful Post: |
11-08-2012, 02:30 | #5 (permalink) | |
Member: 1577359 Status: Offline Sonork: gokul Thanks Meter: 0 | Quote:
Thank you for your guidance. one thing that i did which made my phone to work is that i inserted a small piece of copper wire(length less than 1 mm) in the external antenna socket and then i found the signal of my phone retrieved back to the normal level . i couldn't understand what makes my phone to work now . can you please explain what is happening with that piece of copper wire . what can i do to make my phone to be normal without that piece of copper wire . Expecting your valuable reply Regards Gokul M | |
11-08-2012, 09:54 | #6 (permalink) |
Member: 1005489 Status: Offline Thanks Meter: 105 | Hi,maybe this solution by robertogsm can help you but i think it is better to do what i already told you.Take the phone to some private repair shop. Good luck, Satch |
