Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
05-11-2006, 09:41 | #1 (permalink) |
Junior Member Join Date: Oct 2005
Member: 194688 Status: Offline Thanks Meter: 0 | SE k300i or for all SE joy stick desolding problem??? Last edited by SA-Abbas; 05-11-2006 at 10:07. |
05-11-2006, 22:00 | #3 (permalink) | |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Quote:
It worked for me evry time without damaging any phone Good Luck!!!!! | |
12-25-2006, 21:33 | #4 (permalink) |
Junior Member Join Date: Dec 2006
Member: 417487 Status: Offline Thanks Meter: 1 | >>Try to clean the old joystic by removing only the pice metal from exterior of the joystic<< You mean the little pins on old joystick? Can you describe it with some picture please? I have the same problem too... |
12-28-2006, 23:49 | #7 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | SE k300i or for all SE joy stick desolding problem Reply to Thread Quote:
regards rashid | |
02-12-2007, 21:39 | #8 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 299902 Status: Offline Thanks Meter: 20 | I had the same problem,using the hot air (or the iron)you may destroy something else.And I had found other solution:Try to clean the old joystic by removing only the pice metal from exterior of the joystic and then cleaning carefully all the contacts. It worked for me evry time without damaging any phone Good Luck!!!!! are you saying that you remove the upper part of the joystick then clean the inside and it works .l really wanted to try that but was not sure if it would work. l went and bought every joy stick you can finde for repairs then l found out l can not replace the dam things. |
All SONYERiCSSON JOY STiCK SOLUTiON iN FORMULA | haiderymobiles | Sony Ericsson Hardware Repair | 18 | 06-01-2009 00:33 |
Microsoft Transceiver v3.0 for Bluetooth - New BT stick - Old problem! | The Man | Bluetooth-Software | 10 | 04-06-2009 16:32 |
What is the best unlocking tool for all SE? | afrodizzy | Sony Ericsson | 9 | 09-03-2005 15:54 |
v2.00b is ready. CRUISER is still the best SW for all SE-phones. | foony | Cruiser Suite | 30 | 01-17-2005 22:11 |
