SE K310i keypad n joystick problem Need solution for key "*","0","#" joystick not work:confused: |
bro there is no keypad ic so please first check ur external keypad then check internal keypad connector if all are ok then check upper side of simtry. u see there is some variable rasistor in black shape repacle these or remove and make jumper then check ur problem must be solve |
how to make jumper for my problem? |
i have problem too plz help me |
i am iranian i have a k310 123 and... no work |
More Joystick and Keypad track SE are same if Joystick track broken and Keypad OK, make jumper to both of them. Also if keypad broken and Joystick track OK, same, jumper. to find track, search K500 Joystick solution in this forum and you can find the solution. |
1 Attachment(s) This exemple for Joystick K310 or K510. 4 track is can direct to line keypad. and it same for K500 K508 K700 |
i hav its solution but can you like to tell me how can i attach pic |
thanks mr bocahklaten ur solution worked i repaired one k310i set with *,0,# i made jumper to joystick left middle point and it worked thanks |
k310 i pls help.the print for the centre point is no longer there pls help.where is the point. |
i hv K310i it is not working right side and downside i hv changed the joystick and all prints hv on the board what should i do ??? plz help me |
k310i right side and downside i hv K310i it is not working right side and downside i hv changed the joystick and all prints hv on the board what should i do ??? plz help me:( |
any way thnx i hv solved my K310i joystick problem....it was the print problem right hand side 3rd print was missing and i made the jumper from the joystick and its working now....... thnx to every body who is working in this forum :) |
sony k 310i key ped problem sony k 310i key ped ic jumper i need key ped is not work |
