Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
11-05-2007, 04:28 | #2 (permalink) |
Freak Poster Join Date: Sep 2006 Location: punjab
Member: 357914 Status: Offline Thanks Meter: 71 | bro there is no keypad ic so please first check ur external keypad then check internal keypad connector if all are ok then check upper side of simtry. u see there is some variable rasistor in black shape repacle these or remove and make jumper then check ur problem must be solve |
11-13-2007, 16:06 | #6 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Ngemut Penthil
Member: 295100 Status: Offline Thanks Meter: 212 | More Joystick and Keypad track SE are same if Joystick track broken and Keypad OK, make jumper to both of them. Also if keypad broken and Joystick track OK, same, jumper. to find track, search K500 Joystick solution in this forum and you can find the solution. |
The Following User Says Thank You to bocahklaten For This Useful Post: |
11-13-2007, 16:11 | #7 (permalink) |
Member: 295100 Status: Offline Thanks Meter: 212 | This exemple for Joystick K310 or K510. 4 track is can direct to line keypad. and it same for K500 K508 K700 |
The Following 27 Users Say Thank You to bocahklaten For This Useful Post: |
11-23-2007, 17:36 | #8 (permalink) |
Freak Poster Join Date: Feb 2007 Location: PATHAN MUNDA
Member: 445967 Status: Offline Sonork: 100:1652029 Thanks Meter: 37 | i hav its solution but can you like to tell me how can i attach pic |
The Following User Says Thank You to shmily For This Useful Post: |
02-06-2008, 21:23 | #11 (permalink) |
No Life Poster Join Date: Oct 2007 Location: nigeria kano
Member: 599669 Status: Offline Thanks Meter: 115 | k310 i pls help.the print for the centre point is no longer there pls help.where is the point. |
The Following User Says Thank You to Teepat For This Useful Post: |
03-20-2008, 09:18 | #13 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | k310i right side and downside i hv K310i it is not working right side and downside i hv changed the joystick and all prints hv on the board what should i do ??? plz help me |
03-20-2008, 09:36 | #14 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | any way thnx i hv solved my K310i joystick problem....it was the print problem right hand side 3rd print was missing and i made the jumper from the joystick and its working now....... thnx to every body who is working in this forum |
w700i keypad & joystick problem | k_abhi | Sony Ericsson Hardware Repair | 2 | 01-04-2010 16:23 |
SE Keypad & Joystick Ways ( In One Exe ) | bunty2008 | Sony Ericsson Hardware Repair | 2 | 03-14-2009 15:48 |
SE K310 & K510 joystick problem | TheRascal | Sony Ericsson Hardware Repair | 3 | 11-25-2007 22:09 |
se k750i keypad+joys stick problem | nomi | Sony Ericsson Hardware Repair | 6 | 12-04-2006 08:36 |
