Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
08-26-2009, 17:05 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: United State
Member: 229658 Status: Offline Thanks Meter: 60 | sony ericsson c902 charging problem I have a sony ericsson C902 showing the above error while charging, even with the original battery and the followed come charger.any solution? |
The Following 3 Users Say Thank You to tr3pplea For This Useful Post: |
09-10-2009, 16:41 | #2 (permalink) |
No Life Poster Join Date: May 2006
Member: 275689 Status: Offline Thanks Meter: 64 | Bro, flash the phone with the latest flash file. It should solve your problem, coz today i got a SE W595, Which had same problem as yours, i coudnt charge the phone and " BATTERY CANNOT BE CHARGED YOU MUST USE A SONY ERICSSON BATTERY" message came up, every time i plugged the charger in. I also had a another problem with it, which was that the phone had no signal, and kept on coming up NO SERVICE, but after i flashed it, its all working fine. It charging up well and also the signal is full now. Try it and post results. |
09-10-2009, 16:42 | #3 (permalink) |
09-12-2009, 10:23 | #7 (permalink) |
Member: 275689 Status: Offline Thanks Meter: 64 | I dont know, what to suggest then. I mean flashing worked for me. I jus flashed it once. Did you flash with the latest flash file? and did you use both files: main generic and FS? I suggest try flashing again, but with a another version of files. Or maybe ask some Product Supporter here, on this forum, to help you. |
11-25-2009, 12:16 | #13 (permalink) |
Freak Poster Join Date: May 2005 Location: greece(athens) Age: 42
Member: 142723 Status: Offline Thanks Meter: 32 | i have also this probelm butt i cant trace this fault still,butt i chek it its battery connector's ''btemp'' point gives more readings then other working set.so that it is 100% hw fault. |
11-26-2009, 09:49 | #14 (permalink) |
Freak Poster Join Date: May 2004 Location: Macedonia Age: 54
Member: 65593 Status: Offline Thanks Meter: 17 | I have the same problem with two W595 .....Flashed with latest version..no results.. One from this telephone its new...That its confuse all situation?? |
11-26-2009, 10:13 | #15 (permalink) |
Junior Member Join Date: Jun 2007
Member: 534456 Status: Offline Thanks Meter: 4 | I have the same problem with w850i,after flashing the gdf setup failed.pls help me [email protected] |
sony ericsson C902 freezing problems. | ahl | Sony Ericsson Hardware Repair | 6 | 04-08-2015 05:37 |
SONY ERICSSON P1 charging problem | ameerali19 | Sony Ericsson Hardware Repair | 2 | 08-08-2010 15:52 |
Sony Ericsson C902 Dummy Phone - Original | IPMART | ipmart WebShop | 0 | 09-09-2008 12:20 |
how to unlock sony ericsson c902 | baner2221 | Sony Ericsson Hardware Repair | 3 | 09-08-2008 14:17 |
Sony Ericsson C902 Finalisation problem!!! | aremaboy | KULANKENDI Server | 1 | 07-14-2008 21:16 |
