Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-11-2009, 18:16   #1 (permalink)
Member: 1007965
Smile sony turned on said configuration error?
I turned on phone after it had died an i had charged it. I turned it on an after it was done doing it normal up load thing that it does, A box showed up on the screen that said "Configuration error. Please contact your service provider or service center.
i can't get to anything at all. it won't allow me to do anything. i need my phone. can some one please help me. an might i add im phone technology dumb so to the person that can help me or persons can you explain how to fix it in detail.
thank you,
annheart
Old 04-11-2009, 19:39   #2 (permalink)
globalsystem's Avatar
Member: 521295
Sonork: 100.1657160
Thanks Meter: 172
@ annheart
very simple! you have problem in s/w not h/w
use xs software and customize your phone .if you have some knowledge in gsm you have to complete your phone ;-)
Old 04-12-2009, 02:14   #3 (permalink)
Member: 210255
Thanks Meter: 12
if you have no idea of gsm !! most likely not as you woudnt post in this fourm room for help
run sony updater from sony site and update your fone all will be well
Old 04-12-2009, 10:11   #4 (permalink)
Member: 805427
Thanks Meter: 2
if u r using S E tool software before flashing go to setting n check complete phone after flash n then unlock phone after flash n then flash the fone ur problem will b solved
Old 04-12-2009, 10:34   #5 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,925
thank you,
annheart
U cant unlock ur set if u have configuration error..
u did one thing wrong while u flash ur set
u did Not cheK '' COMPLETE PHONE AFTER FLASH'' in setting Tab.
now u have to reflash the set with same flash files and should be COMPLETE AFTER FLASH..
reflash and post ur results..
regard
Naveed
w550 Sony ericsson Mobile Error Configuration error Please Contact Your Network Oppe Ravi Potdar Sony Ericsson 12 10-26-2014 13:17
Blackberry 8100 won't turn on shows battery error message a.w.m.wafaz BlackBerry (RIM) 8 04-30-2010 19:17
Chines model wont turn on nadirghazi Infinity-Box 3 03-30-2010 17:24
C902 - doestn turn on and flash error Maresch Cruiser Suite 3 02-05-2009 08:50
***k310i error unlock, turn on the phone, no turn on*** plopez Universalbox 2 10-05-2008 07:52
Page generated in 0.27593 seconds with 8 queries
