Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 03-05-2012, 06:46   #1 (permalink)
prabath manjula's Avatar
Member: 1156649
Sonork: 1156649
sony w850 help flash ok blink here
MCU_ID : 99000301FFFFFFFF
S_BAUD : 921600
P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M
FLSH_ID: 897E [Intel SIBLEY]
M_CERT : 52 RED
IMEI : 352401-01-503207-0
CD_PAF : 1 0 1
OTPCID : 49 RED
CID_UP : 4952
CXC_NR : cxc1250489 R1ED001
CDA_NR : CDA102568/13 R2A
P_LOAD : 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
IMAGE : W850_R1ED001_MAIN_CHINA_CY_RED49.bin
Certificate Warning, SSW_CID Mismatch: 49<>52
Certificate Error F.2: -10
FlashImage Certificate Rejected
Flashing Failed, 00:01
SHUT DOWN FL ...
S_BAUD : 921600
M_CERT : 52 RED
CD_PAF : 1 0 1
OTPCID : 49 RED
CID_UP : 4952
IMAGE : W850_R1KG001_MAIN_VODAFONE_CY_RED52.bin
WRITTEN: 460 Block(s), 07:46
IMAGE : W850_R1KG001_FS_EUROPE_1_RED52.bin
WRITTEN: 229 Block(s), 03:51
P_LOAD : 070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
IMAGE : HB1-06 Gen_CDA102568-110_R8A_S-ASIA-LEVAN.bib
Write/Create: tpa/
Write/Create: tpa/preset/
Write/Create: tpa/preset/custom/
Write/Create: tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm
Write/Create: tpa/preset/custom/Customize.xml
Write/Create: tpa/preset/custom/FM_PICTURES_HOOK_3.itm
Write/Create: tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
Write/Create: tpa/preset/custom/FM_THEMES_HOOK_3.itm
Write/Create: tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
Write/Create: tpa/preset/custom/GAMES_HOOK_3.itm
Write/Create: tpa/preset/custom/MEDIA_PLAYER_HOOK_3.itm
Write/Create: tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm
Write/Create: tpa/preset/custom/preloaded_config.xml
Write/Create: tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm
Write/Create: tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm
Write/Create: tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm
Write/Create: tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm
Write/Create: tpa/preset/custom/VIDEO_PLAYER_HOOK_1.itm
WRITTEN: 18 File/Folder(s), 00:07
Flashing Done, 12:33
SHUT DOWN CS ...
Old 03-05-2012, 07:19   #2 (permalink)
Member: 1015551
repair gdfs and try,if not change upper keypad strip
Old 03-07-2012, 10:19   #3 (permalink)
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
yes man do as above , but with hwk u can't completely repair ur set . use setool for gdfs repair.
post result
Old 03-07-2012, 11:28   #4 (permalink)
Member: 457470
S_BAUD : 921600
M_CERT : 52 RED
CD_PAF : 1 0 1
OTPCID : 49 RED
CID_UP : 4952
SHUT DOWN FL ...
S_BAUD : 921600
M_CERT : 52 RED
CD_PAF : 1 0 1
OTPCID : 49 RED
CID_UP : 4952
Write/Create: tpa/
SHUT DOWN CS ...
change the upper IK board and flex and c
Old 03-10-2012, 04:32   #5 (permalink)
Member: 1156649
Sonork: 1156649
iam change it upper board and flex
no this problam same ..........................?
Old 03-10-2012, 13:41   #6 (permalink)
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
change flex+uper logic bord+lcd then post result
The Following User Says Thank You to R@SEL.NET For This Useful Post:
Old 03-10-2012, 14:50   #7 (permalink)
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727
Really Dear Brother I'M specially Believe of Your Suggestion About Sonyericsson.
Old 03-10-2012, 15:33   #8 (permalink)
Marscel_Jr's Avatar
Member: 1121495
step1. cek flexible
2. cek board lcd
3. cek lcd..
good job tested by me
Old 03-12-2012, 05:10   #9 (permalink)
Member: 1156649
Sonork: 1156649
thanks all
thanks all friend i change lcd i try it repoart then
Old 03-29-2012, 02:53   #10 (permalink)
Member: 1686758
thenk bosssssssss....................................... .............................
Old 09-22-2012, 13:40   #11 (permalink)
george gsm's Avatar
Member: 14200
after more files tries to flashing, make cid 53 from 49 and repair software without success, i change the flex pcb cable. that was the problem. original pcb cable look good but is not ok
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.34909 seconds with 11 queries
