Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 02-19-2017, 09:44   #1 (permalink)
Member: 2641406
Thanks Meter: 84
Sony Xperia M2 problem with the microphone [solution]
Microphone repair by mobile technician:
http://www.youtube.com/watch?v=/-TroiTJ5zcw
The Following 2 Users Say Thank You to Baladeva For This Useful Post:
Old 03-14-2017, 10:05   #2 (permalink)
Member: 1518920
Thanks Meter: 16
nice work, I damage the mic everytime when I disassembly this phone
The Following User Says Thank You to karmellino For This Useful Post:
Old 03-15-2017, 12:19   #3 (permalink)
Member: 2641406
Thanks Meter: 84
You need to be very careful while doing it. Try to find proper disassembly kit which allow you to lift hinges without damage.
The Following User Says Thank You to Baladeva For This Useful Post:
Old 05-27-2017, 16:01   #4 (permalink)
Member: 1518920
Thanks Meter: 16
Thanks man, I buy professional kit and now everything goes as it should, very smooth, didn't expect that tools are so important
Old 06-03-2017, 18:47   #5 (permalink)
Member: 2634426
Thanks Meter: 15
What kind of tools did you buy mine is worn out and I would like to invest in pro kit.
Old 06-08-2017, 07:17   #6 (permalink)
Member: 2724771
Thanks Meter: 12
I buy ifixt pro tools equip, it is a little bit expensive but it is worth this amount of money, best quality on the market
Old 06-09-2017, 07:05   #7 (permalink)
Member: 2634426
Thanks Meter: 15
Good stuff danielsoon, do you know if it will be fit for the laptop repair?
Old 06-14-2017, 19:00   #8 (permalink)
Member: 2630469
Thanks Meter: 8
I reccomend to use laptop pro tool kit, with such a equipment you will dissasembly each laptop in your service
Old 06-20-2017, 06:58   #9 (permalink)
Member: 2641406
Thanks Meter: 84
There are special tools for laptops, so keep in mind that they are slightly different from the mobile phone tools. Always ask seller before buying if the mending set will be proper for laptop use.
Old 08-10-2017, 07:35   #10 (permalink)
Member: 2724771
Thanks Meter: 12
Hi bro, again I need your help, I bought Xperia Z3 Compact, but it turns out that it is broken. The only thing which showing up is red light, any solution?
Old 09-22-2017, 07:08   #11 (permalink)
Member: 2748073
Thanks Meter: 8
hello danielssoon I have lately found solution for it, let me know if it works for you:
http://www.youtube.com/watch?v=ZyCeNfc99a0
The Following User Says Thank You to milek12 For This Useful Post:
Old 10-03-2017, 06:28   #12 (permalink)
Member: 2724771
Thanks Meter: 12
Good job milek12 you have helped me a lot, know everything works as it should, now I will know how to handle such a problem.
Old 10-10-2017, 13:05   #13 (permalink)
Member: 2641406
Thanks Meter: 84
Befor the soldering apply caption tape on the components, other way you can damaged the pcb.
Old 10-18-2017, 15:32   #14 (permalink)
Member: 1518920
Thanks Meter: 16
works for me 10 minutes of soldering and it is as new now
Old 11-06-2017, 10:18   #15 (permalink)
Member: 2641406
Thanks Meter: 84
Yes it works perfectly. If you have any further problems send me the PM
Page generated in 0.15035 seconds with 8 queries
