Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 03-02-2015, 10:44   #1 (permalink)
Member: 2355491
Red face sony xperia z3 no vibrate problem
Hi guys i have an sony xperia z3 d6653
Vibrate not working
Vibrate motor is ok
Flex ok
Reflash done
But still no luck
Any suggestions?
Maybe the vibrate driver ic but i have no schematic
Thanks in advance
Old 03-03-2015, 20:44   #2 (permalink)
Member: 1648562
Thanks Meter: 5
Hi Peter,
Were just facing exact same problem with Xperia Z3.
As no schematics available difficult to diagnose.
I have found the issue with no vibration on Z3. Vibration fuse was ****n.
Replace or jumper the fuse solved the problem.
See picture in attachement for the fix.
Good luck and let us know if it has worked.
The Following User Says Thank You to gjnijenhuis For This Useful Post:
Old 03-03-2015, 20:55   #3 (permalink)
Member: 1648562
Thanks Meter: 5
Sorry attachement is not working, giving error. Also can not post links since I have too few posts. Please PM for the picture with details.
Old 03-08-2015, 16:57   #4 (permalink)
Member: 116891
Thanks Meter: 15
Check the fuse marked with blue
The Following 5 Users Say Thank You to GSM_LORD For This Useful Post:
Old 03-09-2015, 10:43   #5 (permalink)
Member: 1648562
Thanks Meter: 5
Thanks. That is exactly the fuse I was talking about
Old 03-11-2015, 02:34   #6 (permalink)
Member: 2355491
Thanks i'll give it a try
Old 03-11-2015, 03:05   #7 (permalink)
Member: 2355491
Ive tried it and it only keeps vibrating
The vibrate wont stop even the phone is off
Old 04-15-2015, 09:21   #8 (permalink)
Member: 2372667
how to test vibrator with external power?
Hi. I've got sort of the same problem, but don't know what (or how to) do...
I can't get the vibrator to work after screen replacement.
Changed the flex cable and SUB board but still no vibration.
Can anyone help me with this?
  • How can I test if the vibrator is working with external power?
  • How can I test if fuse is ok?
asandven.
Old 04-15-2015, 23:55   #9 (permalink)
Member: 1446199
Same problem no vibration after screen change
Old 05-05-2015, 13:23   #10 (permalink)
Member: 1327068
Thanks Meter: 2
Exactly working for me thanks����������������
Old 07-02-2015, 12:14   #11 (permalink)
Member: 2420679
Very THX for your solution! jumper on fuse solved my problem
Old 07-08-2015, 09:12   #12 (permalink)
Member: 2304907
a lot of THX for your solution! the jumper on fuse solved my problem (:
Old 07-28-2015, 00:39   #13 (permalink)
Member: 2435290
do you know where's the jumper i z3 compact?
Old 08-18-2015, 14:48   #14 (permalink)
Member: 3212
Thanks Meter: 10
For Z3 compact it's just bove the connector of the button/vibrator flex. Just locate the "A"
The Following User Says Thank You to thagangsta For This Useful Post:
Old 08-18-2015, 14:51   #15 (permalink)
Member: 3212
Thanks Meter: 10
Originally Posted by gjnijenhuis View Post
Hi Peter,
A big thanks! This problem was about to give me some headache...
Luckily this solution was available. Happened also after changing full front, which was original, so full frame.
Has anyone a explanation for this issue?
Just a simple short to ground after partial assembly during tests...or....ESD....or?...
Page generated in 0.20666 seconds with 9 queries
