Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
03-02-2015, 10:44 | #1 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2355491 Status: Offline Thanks Meter: 0 | sony xperia z3 no vibrate problem Vibrate not working Vibrate motor is ok Flex ok Reflash done But still no luck Any suggestions? Maybe the vibrate driver ic but i have no schematic Thanks in advance |
03-03-2015, 20:44 | #2 (permalink) |
Junior Member Join Date: Sep 2011 Location: Netherlands / OV / Hengelo Age: 39
Member: 1648562 Status: Offline Thanks Meter: 5 | Hi Peter, Were just facing exact same problem with Xperia Z3. As no schematics available difficult to diagnose. I have found the issue with no vibration on Z3. Vibration fuse was ****n. Replace or jumper the fuse solved the problem. See picture in attachement for the fix. Good luck and let us know if it has worked. |
The Following User Says Thank You to gjnijenhuis For This Useful Post: |
03-03-2015, 20:55 | #3 (permalink) |
Member: 1648562 Status: Offline Thanks Meter: 5 | Sorry attachement is not working, giving error. Also can not post links since I have too few posts. Please PM for the picture with details. |
04-15-2015, 09:21 | #8 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2372667 Status: Offline Thanks Meter: 0 | how to test vibrator with external power? Hi. I've got sort of the same problem, but don't know what (or how to) do... I can't get the vibrator to work after screen replacement. Changed the flex cable and SUB board but still no vibration. Can anyone help me with this?
asandven. |
08-18-2015, 14:51 | #15 (permalink) | |
Freak Poster Join Date: Feb 2001 Location: Netherlands Age: 39
Member: 3212 Status: Offline Thanks Meter: 10 | Quote:
Luckily this solution was available. Happened also after changing full front, which was original, so full frame. Has anyone a explanation for this issue? Just a simple short to ground after partial assembly during tests...or....ESD....or?... BR | |
