Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
11-07-1999, 22:57 | #1 (permalink) |
Insane Poster Join Date: Jun 1999 Location: sthlm
Member: 225 Status: Offline Thanks Meter: 5 | Ericsson Cable Interface I've recently built a new Ericsson Cable interface, cause my old one based on the schematic that can be found at www.mobile.8m.com , got broken. So I designed a new interface based on a MAX202 instead of MAX232 and instead of taking the power from the phone I took it from the COM port (RTS & DTR to a 7805 Voltage regulator, like some Nokia Interface!). But some progs like Ericsson Home Service v1.7 doesn't work anymore it worked perfectly with my old cable, but not anymore. When I run Ericsson Home Service "Erserv32.exe" (with a 628) it says: Ericsson 6xx or 7xx detected Enter TEST mode ... Failed to enter SP mode ... I don't know why it doesn't work... The cable interface works with "Ericsson 6xx and 7xx Testmode software by Zulea", and Ericsson Unlocking Software 1.3, And Ericsson All Service Software for EMMA. So the cable ain't dead.. And I've also tried to use the ZOC scripts for 868 to enter TEST MODE, but it doesn't work there either. When I press the "NO" button i see "F" on the screen followed by some crap and then the phone turns ON. AG: What cable are you using for 8xx? What could be wrong?? I've tested taking the power from the phone instead of COM1 but it still doesn't work, with some progs. Anyone who knows what causes the problems? B.R. /F |
11-08-1999, 04:14 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Hi, i had the same problem with GA 628. New models of GA628 are protected just like that ... it can't enter in Test mode. But, i resolved this problem very simply : Opened the phone, read eeprom, and used a simple NCK viewer. Then ... just unlocked the phone by entering code. regards, Alex.
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
11-10-1999, 04:17 | #4 (permalink) |
Junior Member Join Date: Nov 1999 Location: Nish, Serbia, Yugoslavia
Member: 648 Status: Offline Thanks Meter: 0 | Some of programs U are using use hardware handshaiking (rts/cts activity), and some are not (that's why U don't have power supply in your interface) Solution 1: Give it external power supply Solution 2: Use power from the phone (you have pin with +5V if you noticed) DeChec |
11-13-1999, 03:12 | #7 (permalink) |
Member: 648 Status: Offline Thanks Meter: 0 | This talking is becaming useless... Look at it in my way: A. I don't have EMMA Box. B. I have Ericsson cable TYPE 4040017 C. All my EMMA software works properly with it! My solution is this: Don't waste time to make something what is allready made. 1. Find one ERICSSON Data Cable TYPE 4040017 (Goes in pack SH888+CD+Data cable <- what you need) 2. Open it & make one small short-cut (if you don't know which, don't be afraid to e-mail me) And that is all. BTW Use it on fully charged battery! Dechec |
11-14-1999, 02:48 | #9 (permalink) |
Member: 648 Status: Offline Thanks Meter: 0 | I use GA628, 688, 768, 788, 788e with GSMFlash for EMMA and it works perf. So, to stop this once for all who wants to put my schematic & refabricating of original cable on its Web site? mail me. Dechec P.S. Does anyone has scematics for Bosch C-Bus i-face? |
Mss4 Box As Universal Cable Interface | bluffmaster | MSS Box II | 1 | 07-03-2008 08:01 |
I need fbus cable interface | Tulga | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-28-2004 15:40 |
Need 9xx cable interface.... | vid | Infineon C16X M51 & ARM7 M52 BASED | 0 | 09-19-2000 06:17 |
Change ericsson cable | hercules | Sony Ericsson Hardware Repair | 1 | 06-15-1999 16:19 |
