Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-08-2002, 10:22   #1 (permalink)
GSM Coolhawk's Avatar
Member: 7751
Thanks Meter: 74
T28 call dropping. funny one
Hi all
Had a T28 yesterday with the following fault.
Power on, finds network, 3 bars. after 3 min "No Access", but in those 3 min if a call was attempted, when it starts connection after 3 sec, it just dropped the call with a "beep".
Following have been changed in the this T28, in sequence like this
1 : PA
2 : Antanna Switch
3 : TX mixer circuit
4 : RF signal processor <--- This one is normally the culprit as I have noticed fromn other phones ( Made by Ericsson )
5 : 13MHz Crystal Module
And you know what after all this, the SAME fault still remains, aint that a bugger !!!
Anyone had one of these before ?? Any suggestions ??
Regards
Old 12-11-2002, 17:24   #2 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
heat the 2 IC`s under the processor if nothing change them
Old 12-11-2002, 20:10   #3 (permalink)
Member: 7751
Thanks Meter: 74
@jokkergsm
You mean the flash IC and The MMCC, if so I've already done that, reballed both of them, and upgraded the software, still the same.
Thanks for replying
Regards
nokia 2112 in call drop, call ended, no outgoing ashish mobile Nokia Hardware & Hardware Repair 0 05-02-2009 07:53
moto A920 . call drop /call failed celcom Motorola P2k 0 01-10-2005 11:42
3310 dropped --> funny imei Hanukkah Nokia Hardware & Hardware Repair 4 09-11-2002 02:53
A35 can't make call, call dropping pali Siemens Hardware Repair Area 1 06-03-2002 04:51
8210 ... & ...6210 weak signal problem..call drops...sinal drop PTR999 Nokia Hardware & Hardware Repair 3 04-17-2002 14:06
Page generated in 0.14411 seconds with 9 queries
