Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 11-16-2010, 16:31   #1 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
U1 Satio tuch problem
The phone is all new, but the tuchscreen is not working, its always pushing a right down corner, i replaced the tuchscreen with new one, but the problem still the same. Any idea?
ps i tried a many sw versions with setool and fabric updater but not helped!!!!
Old 11-17-2010, 03:47   #2 (permalink)
Member: 1389083
have you tried the touch screen calibration?Also what provider and firmware you have?
Old 11-17-2010, 07:53   #3 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
Ui i tuch problem
Explain me how to calibrate tuch if its not working, the phone is origninal, not branded but i tried with many firmwares orange, voda, t-mobile but a same s..t!
Old 11-18-2010, 02:16   #4 (permalink)
Member: 1389083
Yours is pretty bad I had an issue with the orange firmware when i debranded to azn firmware all those anoying problems went away
Old 11-18-2010, 02:20   #5 (permalink)
Member: 1389083
Also you can go to service menu and check everything press Red Green Red Red Green Red
Old 11-19-2010, 18:04   #6 (permalink)
Member: 1389083
Alright i was changing my screen also and i got a bad digitizer it was sticking on lower right corner on exit, put mine in works also there is sticky stuff there to hold the digitizer in that's another issue without that digitizer does not get *** connection if i put pressure on the connection it works try to do that just a little pressure and see if anything changes
Old 11-20-2010, 00:05   #7 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
This is not working forme, i can get in to a service menu but i cant do anything because if i tuch the screen it exits...
Old 11-20-2010, 00:07   #8 (permalink)
microtel's Avatar
Member: 44395
Thanks Meter: 7
sorry but i dont understand you cristaly, what is digitizer for you?
Old 11-20-2010, 02:47   #9 (permalink)
Member: 1389083
digitizer is a screen the one you replaced it has connection in the back 4 pins if those pins dont get good connection your screen does not work i pressed on the edge of the top right side and i can use the touch screen functions
Old 11-20-2010, 02:51   #10 (permalink)
Member: 1389083
My cousin got a satio also i took off the front panel with the screen and installed it on my phone and everything started to work i didn't even want to give it back to her the problem is that screen suppose to stick really tight or you will get bad connection on ebay now they are selling front panel with the screen already together for 17.00 dollars im going to try it and see how it is
Old 02-08-2018, 03:49   #11 (permalink)
Member: 2808862
i have the same problem i replaced the tuch screen but also the same .
help me !!!
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 09:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 16:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 01:44
Page generated in 0.32449 seconds with 8 queries
