Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
04-18-2009, 16:20 | #6 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Uk (Birmingham)
Member: 719944 Status: Offline Thanks Meter: 2,117 | hi man....i m from birmingham..u can unlock w200 easily with setool man... 1st of all connect ur phone with usb cable by pressing c or 2+5 key...then indentify and check phone cid...after that slect same cid flash files and check use server and complete phone after flash...then press flash botton..by pressing same c or 2+5 key....after flash ur phone...turn on ur phone and wait untill ur phone completly on with same network sim card.....after that again identify ur fone and check there is restoration file is present....after present resturation file...check sign mode and alternative scurity by pass and press unlock.... i hope do understand hope ur problam will solved |
04-20-2009, 12:06 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | w200 unlock Quote:
post ur cid then helping to u very easy. otherwise most of w200 have cid 52. use the v.0.914023 of setool. first identify the phone. if cid 52 and see the version. put the main file of w200 have same version in identify then go to setting tab and tick the ( complete phone after flash, unlock after flash, use server. then click unlock and repair.) post the result | |
W200 (roggers) Insert correct simcard | menake | SETool2 | 9 | 02-10-2011 05:49 |
w550 insert correct simcard | jmustufa | Sony Ericsson Hardware Repair | 5 | 01-24-2008 17:17 |
w850i insert correct simcard (not simlock) | rado_elektrado | Sony Ericsson | 8 | 01-18-2007 12:22 |
insert correct simcard | akhil_bbsr | Sony Ericsson Hardware Repair | 4 | 06-26-2006 14:17 |
R600 insert correct simcard | jerrel | Sony Ericsson | 19 | 03-04-2005 15:15 |
