..::w200 mic problem::.. w200 mic not working,when i record in recording option,it gives sound but when calling no voice pass through mic continuty is ok |
Try to remove and change the ringer ic.. May be your ring is damage too.. Ringer ic in SE same as Nokia like ringer ic 6100.. Thkss |
dear mic problem not ringer |
change mic ic ur set 1000% ok Hariom |
Yes bro!! I got problem same as u.. tRy that!! |
rehot ic or change it...............; |
which ic? confusing |
still no solution???????????????????? |
Change it!!! Try to change IC brother... I often got the same problem in SE like K750,K800.. U can solve this problem by.. Change ringer IC, Vincent IC or Up-Grade ur phone.. I used DB tools for this.. Thkss. |
first reset your mobile then change your sim |
dear problem already solved by change mic ic |
W200 mic Brother i have also same coplaint w200. How can solve? Pls give me picture.... |
W200 mic Brother i have also same complaint w200. How can solved? Pls give me picture.... |
change mic ic |
needed jumper mic w200&ringing,please......help............ |
