Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-03-2008, 21:00   #1 (permalink)
bhgsmservis's Avatar
Member: 45427
Thanks Meter: 141
W380 Buzzer Solution 1
BHGSMSERVIS
p.s. please dont ask for more
The Following 27 Users Say Thank You to bhgsmservis For This Useful Post:
Old 12-08-2008, 04:06   #2 (permalink)
Member: 689942
Thanks Meter: 312
Other solution........
The Following 18 Users Say Thank You to celltellpb For This Useful Post:
Old 01-14-2009, 04:02   #3 (permalink)
Member: 247455
Thanks Meter: 18
sir...please upload solution w380 low buzer....thxxx
The Following User Says Thank You to cpx_cell For This Useful Post:
Old 02-06-2009, 19:54   #4 (permalink)
Member: 206989
Thanks Meter: 3
change flex
100% confirm
The Following User Says Thank You to JULIANCHO For This Useful Post:
Old 05-15-2009, 08:11   #5 (permalink)
Member: 45427
Thanks Meter: 141
Originally Posted by rickoone View Post
Don't try the 1st solution, doesn't work!!! lcd is flashing....wired sound coming from buzzer
You are wrong!!!
This work 100%!
Tested many time!
To All
Dont trust this new (2009) come guy in gsm, whit 1 post !
Old 05-15-2009, 08:23   #6 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
don't try the 1st solution, doesn't work!!! Lcd is flashing....wired sound coming from buzzer
first remove jumper and check again. If there is nolcd flashing and no wired sound from buzzer.
Then
pls. Check your jumper wire . It conect with other pin of connector. If there is too long TINing of jumper wire.
Wbr
Old 05-15-2009, 17:48   #7 (permalink)
Member: 427960
Thanks Meter: 6
no buzzer !
change flex ok 10000000000000% tested by me.i changed 10 phones.it is a best solution
The Following User Says Thank You to lnguyenvu For This Useful Post:
Old 03-29-2010, 15:08   #8 (permalink)
Member: 1198667
Thanks Meter: 4
thanx mr.. .
Old 04-24-2010, 00:25   #9 (permalink)
gsm.magic's Avatar
Member: 931360
Sonork: 100.1592533
Thanks Meter: 539
BHGSMSERVIS
This work 100%Tested many time
thank you my friend
br
gsm.magic
The Following User Says Thank You to gsm.magic For This Useful Post:
Old 04-24-2010, 05:53   #10 (permalink)
portalgsm's Avatar
Member: 423627
Thanks Meter: 261
flex 5 usd men 100% sure
Old 05-19-2010, 00:32   #11 (permalink)
Member: 349474
Thanks Meter: 2
his is a small modification that I make of the jumps to use the filters of the buzzer, I guarantee this way an clear audio
4shared.com - online file sharing and storage - download other style of jumper w380 low buzzer.jpeg
Old 05-19-2010, 00:54   #12 (permalink)
Member: 349474
Thanks Meter: 2
sorry is this 4shared.com - online file sharing and storage - download other style of jumper w380 low buzzer.jpeg
The Following 2 Users Say Thank You to jesusace12 For This Useful Post:
Old 07-24-2010, 00:53   #13 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 100
@jesusace12
thanks, man, your jumper is tested and working, good job!
br
Old 07-26-2010, 19:15   #14 (permalink)
Member: 285779
Thanks Meter: 49
jumper is working but not clear n strange sound like wrong frekuensi .
prefered replace flex
Old 10-09-2010, 23:27   #15 (permalink)
Member: 349474
Thanks Meter: 2
friends, if the flex of the telephone has a bobina, be careful when welding the wire for not watering welding on her, only solder on the extremes, because otherwise they will have distorcion, voltage flaw in the telephone or in the lights
remeber, my jumper are the green ways, forget the red ways, this last are not my jijijiji
regards
w380 buzzer problem solution4mobile Sony Ericsson Hardware Repair 6 03-31-2010 17:53
need moto l6 speaker and buzzer solution rajendrakumar Motorola Hardware Repair 0 09-26-2008 10:23
need n-gage buzzer solution erkan06us Nokia Hardware & Hardware Repair 1 08-06-2007 17:05
need se k500,k508 buzzer solution? HUM Sony Ericsson Hardware Repair 4 02-05-2006 15:51
Panasonic Gd 55 Buzzer Solution! kovacn2 Panasonic 0 01-15-2004 21:17
Page generated in 0.30271 seconds with 11 queries
