Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
02-07-2008, 16:53 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab Age: 44
Member: 476739 Status: Offline Thanks Meter: 507 | w550 IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!! ORIGINAL IMEI:35744300520474 CURRENT IMEI:00000000000000...........imei is bad please help me |
02-07-2008, 16:54 | #2 (permalink) |
Member: 476739 Status: Offline Thanks Meter: 507 | v0.91380096/UNI Card serial:00048290 Loaded 51 flash descriptors ChipID:8040,EMP protocol:0301 OLD EROM, OVERRIDING COLOR OLD EROM, OVERRIDING CID PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35744300520474 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:8040,EMP protocol:0301 OLD EROM, OVERRIDING COLOR OLD EROM, OVERRIDING CID PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:200D Flash props sent ok FOUND: R4BA041_CXC1250087_HONG_KONG_EL Restore from:R4BA041_CXC1250087_HONG_KONG_EL writing F:\se-tool3\FLASH FILE\SONI- ERI\W550\R4GC010_1250031_GENERIC_EL\brown\prepared \w550\r4gc010\R4GC010_1250031_GENERIC_EL.ssw CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:343 Will flash 343 blocks... SSW loading returns:0 Setting up GDFS... IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!! ORIGINAL IMEI:35744300520474 CURRENT IMEI:00000000000000 USB INTERFACE DETECTED AND IMEI IS MISMATCHED USE COM/UFS INTERFACE TO REPAIR THAT PROBLEM ! Clearing total time... Writing simlocks... full sig complete. CSloader version: COMPACT_SEMC_FS_LOADER_SETOOL2_V26 loader startup: executed loader filesystem startup: executed loader GDFS startup: executed loader unlock: executed writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed:493 secs. |
02-07-2008, 17:13 | #3 (permalink) |
Freak Poster Join Date: Sep 2005 Location: pearl of the orient
Member: 177408 Status: Offline Thanks Meter: 20 | on settings: check "allow imei change when unlocking" then go to se tab, ofcourse model should be "w600/w550" then press "unlock/repair" wait... the soft will ask you to enter imei.. just press o.k (make sure imei is same as otp" good luck... |
07-14-2011, 09:51 | #7 (permalink) |
Junior Member Join Date: Mar 2011 Location: h.phone communication
Member: 1545668 Status: Offline Thanks Meter: 0 | RUNNING v 1.07/UNI CARD SERIAL 00068362 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID: 897E OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 CERT:RED ACTIVE CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:10485752551048575 Model (from GDFS):W580i Brand:CTI Movil MAPP CXC article: R6BC002 prgCXC1123362_GENERIC_LA MAPP CXC version: R6BC002 Language Package: AMERICA_2 CDA article: CDA102774/69 CDA version: R5A Default article: cxc1123364 Default version: R6BC002 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R6BC002_CXC1123362_GENERIC_LA" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. help me solve the problem please................!!!!!!!!! |
K310i CID 50 OTP IMEI AND GDFS IMEI MISMATCH | techark | Universalbox | 0 | 10-01-2008 13:43 |
k310i IMEI missmatch!!! possible stolen phone!!?? | eddierasta | Sony Ericsson | 4 | 08-20-2008 10:27 |
Imei change possible on almost all phones | mmcr | UST Pro II | 8 | 05-26-2008 00:45 |
Imei Change On 6070 Phones. Possible? | djssergy | Universalbox | 3 | 12-22-2006 17:52 |
broke my lg8110 possible 2 use imei on barred lg8110 phone | luckveer | LG | 2 | 02-16-2005 18:50 |
