Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
10-13-2006, 16:59 | #6 (permalink) |
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | is this ic same as 6230 keypad ic or its different .. does it also work for k750 joystick ? what is the part number and who is selling |
The Following User Says Thank You to luckycool For This Useful Post: |
10-14-2006, 19:30 | #7 (permalink) |
Junior Member Join Date: Aug 2006
Member: 340885 Status: Offline Thanks Meter: 1 | sir. i hv a w550 with fault of keypad buttns. i changed the key ic & internal keypad but problem solved, if anyone hv any solution of tht problem thn plz give me tht. thks |
The Following User Says Thank You to aman01638 For This Useful Post: |
06-29-2007, 08:31 | #11 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In Heavan
Member: 229987 Status: Offline Sonork: 100.1602834 Thanks Meter: 193 | I m facing kepad problem in W550i Se 4-6 and manu keys r some time working n some time not i checked mother board with replace in other set but mother board is ok problem is in LCD Section i also change flex too but same problem if anyone trace this fault what i do plz help |
06-29-2007, 11:12 | #12 (permalink) | |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | Quote:
also check with ok display pcb path from hing connector to 4-6 and menu on pcb and clean pcb and keypad dot with pensil eraser [ if needed make jumper] wbr | |
nokia5130c kepad not work pls help.......... | jamaletw | Nokia Hardware & Hardware Repair | 1 | 08-08-2009 17:22 |
Nokia 3120 5 kepad not working | riaz-net | Nokia Hardware & Hardware Repair | 9 | 02-05-2009 21:52 |
x430 kepad not work???? | lotharr | Samsung Hardware Repair | 2 | 06-27-2005 11:19 |
N gage kepads not working | celltrix | Nokia Hardware & Hardware Repair | 4 | 06-14-2005 00:13 |
kepad not working 3310 | gbada | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-13-2004 09:18 |
