Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson Hardware Repair Area
Sony Ericsson Hardware Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 05-03-2007, 20:05   #1 (permalink)
Member: 494020
w550i keypad problem
w550i keypad problem this phone is water damage and keypad is not work i will try to change keypad ic but no result plz help me
Old 05-04-2007, 10:38   #2 (permalink)
baraka42's Avatar
Member: 14578
pls. write here detail . what no. key pad not working?
wbr
Old 05-10-2007, 12:31   #3 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
i too have the same problem with key pad,does on/off switch track comes from keypad ic?masters pls respond,handset is phisical damaged,changed nearly 7 keypad ic's
Old 05-10-2007, 14:21   #4 (permalink)
baraka42's Avatar
Member: 14578
remove power switch and clean oxide under it. or reples power switch.
wbr
The Following 2 Users Say Thank You to baraka42 For This Useful Post:
Old 05-10-2007, 16:26   #5 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
thanx mr baraka,usefull tip of the day ,i will try it
The Following User Says Thank You to sajidmirza For This Useful Post:
6700c keypad problem luyanda Nokia Hardware & Hardware-Repair Area 21 03-12-2013 14:20
w550i keypad problem albedo83 Sony Ericsson Hardware Repair Area 33 06-20-2009 07:33
w550i keypad problem alhamde16 Sony Ericsson Hardware Repair Area 8 04-19-2009 12:56
w550i keypad problem RATHNAMOBILESS Sony Ericsson Hardware Repair Area 2 11-07-2008 14:34
w550i keypad problem gct Sony Ericsson Hardware Repair Area 12 03-25-2006 07:31
Page generated in 1.80413 seconds with 12 queries
