w580 camera problem when activating the camera function get message another application is running close it and then start again the camera :D |
try take out n put it back again in the camera holder... If still can't solve the problem, 1. replace camera module 2. replace upper part flex try n post result |
ok replaced camera ribbon its ok now thanks |
i got camera problem i put new flex in the phone but when i slide up the phone it says open phone for camera is there a mechanasim which activates the camera |
its so simple Quote:
bro you replace camra strip problum is that you need to use new strip with 0ld ringer ringer can use to scence the sancer for example ____-___-___ some slide phone has use magnate for sliding for sence slide up down only use orgnal ringer on new strip it can solve your problum post result |
les tengo la respuesta es un cristal yo se cual es |
sorry thats not my post somebody use my user and pass |
http://www.4shared.com/file/11178518...lgsm-vol2.html ic camara 1000%testeado |
ok gracias flaco, muy buen aporte!!!! |
thank's brother Quote:
