Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 09-04-2008, 12:35   #1 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
w580 camera problem
when activating the camera function get message another application is running close it and then start again the camera
Old 09-04-2008, 13:21   #2 (permalink)
Member: 718027
Thanks Meter: 32
try take out n put it back again in the camera holder...
If still can't solve the problem,
1. replace camera module
2. replace upper part flex
try n post result
Old 09-04-2008, 13:21   #3 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
ok replaced camera ribbon its ok now thanks
Old 09-30-2008, 19:09   #4 (permalink)
coolmax's Avatar
Member: 157118
Thanks Meter: 156
i got camera problem i put new flex in the phone but when i slide up the phone it says open phone for camera is there a mechanasim which activates the camera
Old 10-31-2008, 18:50   #5 (permalink)
Member: 824789
Thanks Meter: 2
i have same problem and chang ihf sp it solved
Old 01-22-2009, 15:03   #6 (permalink)
nauman g's Avatar
Member: 459065
Thanks Meter: 469
its so simple
bro you replace camra strip
problum is that you need to use new strip with 0ld ringer
ringer can use to scence the sancer
for example ____-___-___
some slide phone has use magnate for sliding
for sence slide up down
only use orgnal ringer on new strip
it can solve your problum
post result
The Following 2 Users Say Thank You to nauman g For This Useful Post:
Old 05-28-2009, 03:58   #7 (permalink)
Member: 648637
Thanks Meter: 34
les tengo la respuesta es un cristal yo se cual es
Old 06-15-2009, 22:31   #8 (permalink)
Member: 648637
Thanks Meter: 34
sorry thats not my post somebody use my user and pass
Old 06-22-2009, 20:20   #9 (permalink)
portalgsm's Avatar
Member: 423627
Thanks Meter: 261
http://www.4shared.com/file/11178518...lgsm-vol2.html
ic camara 1000%testeado
The Following 2 Users Say Thank You to portalgsm For This Useful Post:
Old 06-24-2009, 18:45   #10 (permalink)
Member: 682331
Thanks Meter: 2
ok
gracias flaco, muy buen aporte!!!!
Old 01-19-2011, 03:26   #11 (permalink)
Member: 395094
Thanks Meter: 58
thank's brother
post result
thank's brother .
w580 camera billa2008 Sony Ericsson Hardware Repair 6 02-01-2010 15:26
w580 camera not visible jmustufa Sony Ericsson Hardware Repair 3 09-12-2009 07:46
w580 camera problem kathir. Sony Ericsson Hardware Repair 1 05-09-2009 22:43
w580 camera prablem imran_mobi Sony Ericsson Hardware Repair 2 03-05-2009 14:05
W580 Camera Problem mtech6928 Sony Ericsson Hardware Repair 0 07-08-2008 09:07
Page generated in 0.25699 seconds with 9 queries
